Type O 3.42:1 Ring and Pinion Wanted
Old Nov 30, 2016 | 11:40 AM
6884rocket's Avatar
I am looking for a good used set of Type O 3.42:1 Ring and Pinion gears, 28 (or is it 27?; unable to clarify) spline which I will be installing in the 2.73:1 - 3.23:1 carrier. If anyone has a set please let me know. Thanks.
Old Nov 30, 2016 | 11:47 AM
oldsmobiledave's Avatar
fyi
There is no 2.73-3.23 carrier. It is 3.08-3.23 (perhaps a typo on your part?).
Won't work without a spacer for OEM gear set. 3.42s were never meant to be installed on the 3.08-3.23 carrier.
You need the Richmond aftermarket 3.42 gears to achieve your goal.
Do you know if you have a 3.08-3.23 carrier or a 2.56-2.78 carrier? Are you sure you even have a 68-70 Type O? Your original post of 2.73-3.23 concerns me.
Good luck with your search
Old Nov 30, 2016 | 08:25 PM
6884rocket's Avatar
Thanks For The Information
Yes it was a typo. Have always been a poor typist. Yes, I do have the Type O in my '68 442. It is the 442 base axle ratio of 3.08:1 aside from the Turnpike Cruiser which was 2.78:1. It appears that I'm going to go with the Richmond Gear set as I don't want to change to the #4 carrier for the OE gears and continue the fruitless search for a good used set. Was not aware that a spacer for the ring could be used in the #3 carrier for OE gears. Good to know for future reference.
FYSA, Yukon also produces the 3.42 and 3.90 for Type O as well but they run about $150.00 more than Richmond.
Thanks for the help. Much appreciated.
Old Dec 1, 2016 | 08:38 AM
68s350's Avatar
hello fellows,
Not to hijack the post but have a similar question.
I have a 68 cutlass with a 12 bolt housing and 10 bolt open differential. Who sells a posi diff hat I could just simply swap in? Not to knowledgeable about rears.
Rich
Old Dec 1, 2016 | 10:19 AM
Rog's Avatar
Rog
supercarsunlimited.com got a set in june oem spec #46-148carrier $ 629. 46-036 3.42 ring&pinion 349.95 inst kit ie bearings shims chrush sleave ect worked well took 4hrs to install and set up I replaced axle bearins and seals it the same time mine is 68 442 type o had 2.23more snap off the line. they were great to work with rog
Old Dec 1, 2016 | 12:42 PM
Cman7713's Avatar
Originally Posted by 68s350
hello fellows,
Rich
Monzaz is the member here you should talk to for a posi swap. I personally went the slow/expensive route and found a whole tm coded 3.42 posi rear.
Old Dec 1, 2016 | 05:50 PM
your 68 gears
A bit tough to read your run on post. Are you saying you had 2.23 gears? Because that never happened.
Old Dec 2, 2016 | 06:02 AM
6884rocket's Avatar
Richmond Is Way To Go
Rich
Sounds like Rog is the go-to guy on differentials. I'm going to go with the Richmond 3.42:1 gears as it is the easiest COA as there is no carrier change. My car was originally ordered as walk-in-and-buy-a-'68 442-dealer stock when new (equipped as a base automatic model with PS and PB as primary options) with the 3.08:1 axle. I swapped the OE SSI 14" x 6' wheels for the Wheel Vintiques reproduction SSI 15" x 7" with P22560R15 rubber. The 3.08:1 functions more like a higher 2.98:1 (no such thing in GM of course) ratio due to the larger rolling stock necessitating the change to the lower ratio for improved street performance and drivability.
If you have the Cutlass S with a 350 your axle should be the Type BOP 8.25" ring gear if it's original. The big-block 400/455 A-Bodies (442 and H/O) were equipped with the Type O. Your new replacement posi unit and gears should be far less costly as that axle went into three A-Bodies and I believe even some of the full size models in Buick, Oldsmobile, and Pontiac. Both Eaton and Auburn produce posi units for your axle and though not cheap they are less costly than Type O units. You get a small break by having the more common axle thus parts are less costly for those guys to produce due to higher volume sales. Capitalism economics at work.
Old Dec 2, 2016 | 06:42 AM
Rich
Big block or small block makes no difference to when the Type O is equipped. Late 67-1970 is Type O regardless of engine.
Old Dec 2, 2016 | 06:51 AM
6884rocket's Avatar
So only Buick and Pontiac shared the BOP in the A-Body models? The Cutlass line was all Type O for those four model years? Good to know and sort of bad news for the small block crowd for parts locating and cost-wise.
Old Dec 2, 2016 | 06:15 PM
Fyi
Early 1967 was 10 bolt.
Old Dec 2, 2016 | 06:48 PM
6884rocket's Avatar
Good Information
Roger...tracking all. You're a great information source. I can understand why GM wanted to consolidate their axles into a corporate design. Unfortunately, they went with the Chevy axle which (in my opinion) was OK (due to 8.75" ring gear) but not great due to the u-joint shaft clips instead of bolts. I really do believe the Type O is a better quality axle. Would have improved the billions of Chevys that were made back then. Just my 1.5-cents worth of input.
Old Dec 5, 2016 | 11:28 AM
68s350's Avatar
Rich
Thank you for your info - appreciate it -
Old Dec 5, 2016 | 11:32 AM
68s350's Avatar
spoke to Monzaz- great guy - he said - 12 bolts on housing 10 bolts inside - could only be one carrier- forgot which he said - but after the holidays ill be in touch with him and let you know tha outcome - appreciate all the responses and help.
Old Dec 5, 2016 | 12:29 PM
Nowdays there is an aftermarket posi carrier that is a re-machined Ford 8.8 unit, so that is likely what he was talking about.
As for factory units, there were four different posi carriers for the O-Type rear: three different carriers depending upon the gear ratio and another carrier for the heavy duty 31 spline rear.
#673 = 2.56 & 2.78 ratios, 28 spline
#671 = 3.08 & 3.23 ratios, 28 spline
#588 = 3.42 & anything numerically higher, 28 spline
#672 = 3.42 & anything numerically higher, 31 spline
***The 31 spline axles were offered in late 67-68 OAI cars only.
Old Dec 5, 2016 | 03:40 PM
Pfiffle's Avatar
Monzaz built a drum to drum rear for my 76 Cutlass about 8 years ago and I am Totally satisfied with it! He even sent me progress pics while he was building it. And break-in instructions. I strongly recommend him. A real nice guy too. Straight shooter.
Tom
Old Dec 6, 2016 | 06:24 AM
68s350's Avatar
Tom
the sport needs more guys like that!
joesw31
May 5, 2015 04:58 AM
oldspackrat
Aug 10, 2014 10:03 PM
Napoleon1991
Mar 7, 2014 12:06 PM
warrior71
Jun 23, 2012 05:48 PM
