Water Nipple for Heater Core
Old Apr 12, 2016 | 06:39 PM
1971raresx's Avatar
Does anyone know where I can get a replacement water nipple for the heater core that connects from the intake manifold to the heater core? The only ones that I can find do not have the same configuration with the exit hole being to big and not the same as the original. Any suggestions? This is for my 1971 Cutlass SX 455 V8. Thanks for your help.
Paolo
Old Apr 12, 2016 | 07:44 PM
I moved your post to parts wanted. I'm sure someone has one on here.
Old Apr 13, 2016 | 05:51 AM
ROCKETMAN269V's Avatar
Question
To the best of my knowledge, all heater hose nipples, at the right rear of the intake, are 5/8". There are two different size pipe threads where the nipple threads into the manifold, depending on the model year of the vehicle. If this is the problem that you are having, I should be able to help.
Old Apr 13, 2016 | 08:04 AM
Run to Rund's Avatar
In the early 70s I bought some from the Olds Parts Dept with different restriction holes. All were steel with the screwdriver notches in the top, and 3/8 NPT thread. Is this the type you want, and which hole size?
Old Apr 13, 2016 | 08:16 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Fusick... HHF640 for 64-70 HHF714 for 71-74
Old Apr 14, 2016 | 11:02 AM
1971raresx's Avatar
Great. The whole size is 1/4 on the bottom. That is the exact one I need. Let me know if you have one and how much. Thanks.
Old Apr 16, 2016 | 08:15 PM
1971raresx's Avatar
Thanks for the info. Picked one up from Fusick.
Octania
Aug 11, 2014 01:25 PM
rktolds
May 13, 2014 08:43 PM
W30Olds
Jan 27, 2014 06:28 PM
ent72olds
Vista Cruiser & Wagons
Sep 25, 2010 02:07 PM
silverriff
Feb 24, 2008 05:13 PM
