WTB: Set of good used 6cc or Flat 350 Pistons
Old Apr 22, 2011 | 08:28 AM
I finally got the chance to finish disassembling and measuring my "cheap build" 1976 350, which someone else had had apart in the past.
I hadn't been sure what I'd find, since whoever took it apart the last time may have changed things, but what I found was a standard low-comp. 350 with unmodified #8 heads and 14cc pistons.
I'd like more compression, and plan to get a set of #6 or #7 heads, but it seems my job will be easier with a set of high-comp. pistons.
The motor has surprisingly little wear (no cylinder ridge that I could feel), so I feel okay about just changing pistons and keeping my own rings, which still show a serviceable end-gap. (measurements available on request.)
I'm looking for a set of used 350 pistons with a 6cc dish, or flat-topped, not worn out. My bores are B and C-sized, so A's would definitely be too small.
Probably better without the rods, as mine are fine, but I'll take 'em either way.
I figure someone who did a fancy rebuild on his engine has a set of old pistons lying around that I could use...
Thanks in advance!
Old Apr 22, 2011 | 09:20 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
You have a good idea there, but it may take a while to find what you need.
Old Apr 23, 2011 | 12:53 AM
64Rocket's Avatar
I will look and see what I have. I have two sets, I will check.
Gene
Old Apr 23, 2011 | 08:19 PM
Thanks, Gene!
cdrod
Nov 30, 2014 08:25 AM
Magna86
May 25, 2014 02:24 PM
Oldssupreme
Dec 10, 2012 06:21 AM
Al2011
Feb 29, 2012 06:49 AM
69Rocket350
Feb 28, 2012 07:31 PM
