WTB Passenger side mirror 67' Cutlass
I believe the passenger side (RH) mirror for '67 was a Dealer installed option on all Olds models and not interchangeable with the Driver side (LH) mirror. The complete kit, including mirror, bracket, gasket, screws, and template/install instructions went by part # 982859 for all but the Toronado. The mirror itself was part # 397398 (cast in the bottom). I found one (mirror only) for my '67 Delta on Ebay about 6 mos. ago. Probably paid more than I should have ($100 with shipping) but had been looking for one for a while and they are not all that common. Have not had time to attempt install - and still need to figure out what to do about a mounting bracket and gasket. Not sure if those parts are unique to the passenger side or if the driver side mirror parts will work. Good luck on your quest.
Toros are unique lh& rh bases
But do tell how all th others differ ???
have mirrors / mounts..gasket or 3
Lh remotes...
& reproduce a stainless shaft for 65 &66 mirrors & billet alum mounts as steel shaft rusts in potmetal mount & average removal technics result in snapped shaft & crumbling oxidized potmetal mount
67 repo mount is stainless...lookin back it all seems so clear....
Lh remotes...
Image transfer tips
When uncooperative unproductive sight refuses to let you load pick where they should go
cram em up their backside..load em any where ya can
This is nice one of 67 mirrors...nice aint it !!
Man on moon ...image transfer ...well...
'67 Outside Rearview Mirror
Tried to send a PM but says the box is full. I see you have a number of mirrors, do you happen to have any orphan mounting brackets for a '67 outside mirror?
You can stop hoping
It definatly does exactly that
been 1/2 wasted tryin to get back here
Email pls
Omishjon4@gmail.com
Have you a gasket ?
Email pls
Omishjon4@gmail.com
Have you a gasket ?
