WTB (Maybe) - '68 Type O 28 Spline Axle Shaft (?)
Old Sep 25, 2021 | 03:15 PM
BackInTheGame's Avatar
Hey all,
After reinstallation, I've discovered my driver's side axle shaft has a slight kant to it, out at the flange. My new brake drum rubs on one portion (about 110' worth of rotation) of the brake backing plate as the axle turns. I put a dial indicator on the outer edge of the lug flange and it looks to be about .155" off center. The axle shaft and backing plate were on the car when I bought it. In the meantime, I rebuilt the rear-end, installing anti-spin and new gears, new bearings, seals, etc.. I had marked the axle shafts upon removal so I know I have the correct/original shaft in it's original location. The old brake drums were mis-matched and/or out of spec, so they all went to the recyclers and I bought new for all four corners. When I media blasted and refinished the backing plate, I noticed some unusual wear damage, with a groove where there shouldn't be, and a ridge on the opposite side, again, where there should not be..The right axle rotates smoothly and doesn't make any noise. I know the car had been in a wreck on it's left side due to various indications including left fender replaced, left steering knuckle, brake parts, and drum replaced with Buick parts, frame has been on a rack, etc. i'm guessing the left axle was impacted at the same time. Maybe a curb crunch - who knows, now?
Should I just tweak the backing plate out of the way? Or do I need to replace the axle shaft? Or the shaft and the backing plate?
Thoughts? Suggestions? Parts for sale?
Old Sep 25, 2021 | 03:36 PM
66-3X2 442's Avatar
A 66/67 BOP 8.2 axle is the same as a 68/69 O Type. It may open up the hunt if you need one.
Old Sep 25, 2021 | 04:42 PM
I’d check with the wheel on to see if there’s any noticeable wobble during rotation.
Old Sep 25, 2021 | 06:47 PM
2blu442's Avatar
I'm pretty sure I've got a 1968 rear end that I already sold one axle out of. If you decide you want a used axle I'll dig that one out for you to consider.
John
Old Sep 26, 2021 | 12:05 PM
Thanks, guys!
I'm going to do as Kenneth suggests and check runout with wheel and tire mounted, just for grins. Truth be told, I've decided I'm going to change out the axle shaft. There is just too much interference/rubbing going on. At the point where it rubs it gets very hard to turn by hand. It can be done, but takes some muscle. When it runs in gear (4-spd), with jackstands under the axle, when I disengage the clutch the wheel stops spinning almost immediately.
John, how much would you want for your axle shaft? What does it weigh, about 15 pounds? Shipping will be to 80134.
Rich
Old Sep 27, 2021 | 01:44 PM
2blu442's Avatar
Hi Rich
I just pulled the axle and am attaching photos here. There are some pits in the axle toward the wheel end. But I would be fine running this axle. I'm 99% sure I pulled this rear end out of a 1968 but just to confirm that I'm including a picture of the casting number on the pumpkin. I'll get a shipping estimate and price in a PM to you. John
Old Sep 27, 2021 | 02:21 PM
Thanks, John, much obliged. I don't mind the pitting - it won't show! Can you tell/verify that it is still "true?" Tell me, is the cast number on the inner face of the flange 907033?
This is what came out of mine.
Old Sep 27, 2021 | 03:59 PM
2blu442's Avatar
I rotated the axle in the housing and visually I couldn't see any wobble. This one has the number 907041 cast into it. Here's a picture.
Old Sep 30, 2021 | 01:10 PM
Closing the loop on this thread:
Thanks John. I've pm'd you, let's move on this.
Rich
Old Sep 30, 2021 | 05:28 PM
2blu442's Avatar
Hi Rich
Did you get my reply?
John
Old Sep 30, 2021 | 07:45 PM
Hey, John, No, I've not received anything email or PM since your note including "Zelle," which I did see, but did not respond to. Apologies if that is what you are referring to. Payday is tomorrow
Old Oct 19, 2021 | 04:39 PM
I did receive 2blue442's axle shaft, after it's whirlwind Cross Country Tour, courtesy of FedEx. It cleaned up well, and runs true. I installed it today and now find my suspicions were well founded: my OEM backing plate is tweaked in addition to the original shaft. So now, before looking for a driver's side rear brake backing plate, I'm going to get out the BFH and see if I can drive the outer edge of the backing plate inboard about .030"-.060" That should be enough to provide sufficient clearance. It does turn, just rubs and makes a light metal-on-metal scraping noise.. I'll mount my dial gauge to the axle flange and spin it around to find the high spot.
Old Oct 19, 2021 | 08:03 PM
2blu442's Avatar
Rich, if this doesn't work I have the backing plate off the rear the axle came from. Just let me know if you need it.
John
Old Oct 20, 2021 | 06:08 AM
Thanks for the offer, John. I should know this evening.
Old Oct 20, 2021 | 05:08 PM
John, thanks for your offer, however I was able to correct the issues with the backing plate I have. All is well. A little BFH, a little Grinder, and all is well.
Old Oct 21, 2021 | 02:55 AM
2blu442's Avatar
Good news Rich! I'm glad you have this problem behind you!
John
Tims68Olds
Brakes/Hydraulic Systems
Mar 11, 2020 09:32 AM
slade69
Drivetrain/Differentials
Jan 17, 2020 07:09 AM
RED66CUTLASS
Sep 4, 2014 11:53 AM
72hurst
Apr 21, 2014 04:34 PM
oldspower_68
Jan 1, 2013 09:48 AM
