WTB Driveshaft for 71 442 and wire harness
Need one complete driveshaft for 1971 442 W30 (455 of course) with 400 automatic. 32 spline. Like the idiot I am I tossed mine out when we took our salvage metal to the recyclers. Yes, also tossed out the radiator. Brilliant. Putting the car back together now and need the driveshaft. Bought a new radiator. Also need both engine bay wire harnesses that plug into the firewall - internal regulator. Have a harness from the donor car but it is external regulator. Also tried to fit a driveshaft from our 72 350 442 donor car but it is too long and of course also has the wrong yokes. Canton, Georgia. Richard at acaceca@aol.com
American autowire or MH can get you a new harness
places like the partsplace and im sure others like fusicks can get you a new driveshaft.
be aware automatic cars had a 2 piece driveshaft w the tubes joined w rubber, many have found that rubber union has deteriorated over the years. Dennys driveshaft or a place like fleetpride can ,make you one as well.
Likely could source you an original driveshaft. Friend is clearing out his shop, he parted three or four big block 455 cars. There are outfits (damper doctor etc) that can “redo” the rubber.
I dont know that for sure. AFAIK automatic cars got the 2 piece. I still have the oe 2 piece in my car original 350 now 455 w no issues, but i do have a 1 piece for a spare.
I suspect most failures are realized w sticky tires.
Hello
I have a beatifulll original finish 551/4 center to center solid shaft
th400 shaft with 3 original paint stripes still
probably a n overkill for what your looking for
Scott
2o6-4six5-9165
MY DRIVESHAFT IS SPOKEN FOR 3-16-22
Scott
2o6-4six5-9165
RetroRanger
Just looked at another 71 442 automatic that we have had for a long time and it has a one piece shaft - never knew about the 2 piece
Scott - Right - thanks for the offer but this car is a huge project - and will still be a project when I am done with it. ($$$ spent already - trying to save a few bucks for my old age, which began 30 years ago)
dc2x4drvr - as rocketman stated, shafts are measured from center to center of the ujoints - to be sure, is this the measurement you are using or are you measuring just the shaft length as stated - thanks
