WTB 88-98 passenger side outside mirror
Old Aug 28, 2021 | 02:02 PM
71MidwestDelta88's Avatar
I need & WTB a proper Right (passenger side) outside mirror for my 71 delta 88
Old Aug 29, 2021 | 06:29 AM
deaddds's Avatar
Can you post a photo of your left? Is it manual or remote?
Old Aug 30, 2021 | 03:29 AM
i sure will deadds as soon as it gets light outside
Old Aug 30, 2021 | 03:50 AM
here it is
Old Aug 30, 2021 | 07:10 PM
deaddds's Avatar
Ive got rh mirrors for the matching manual lh but none available for the remote lh currently.
Old Aug 30, 2021 | 07:28 PM
the remote & the manual mirrors are the same size & shape right? if so it doesnt have to be remote, matching the mirror on the leftside is most important, i got one on e-bay that looks correct but the base has a different angle on it making the mirrors edge sit only about 1/4" from the window glass so thats a no-go, so if your are OE mirrors you can let me know what you'll take for one & we'll be in business,tks
Old Aug 30, 2021 | 08:07 PM
rocketraider's Avatar
Oldsdruid
Manual and remote mirrors are different. The manual mirror head pivots on a ball mount on its stand. Remote is shrouded inside its head.
Here's the one you need. Group 10.185, p/n 983280, mirror assembly RH outside, matches LH remote mirror. 71-74 all B (88), C (Ninety Eight), E (Toronado).
Old Aug 31, 2021 | 03:04 AM
thanks very much, i will look for the one from group 10, but if you happen to run across one plese let me know just in case i didnt find one yet
Old Aug 31, 2021 | 06:14 AM
deaddds's Avatar
The remote are expensive if you want nos. Last one if i remember sold for $450. NOS manual will look a little different but IS correct for the car. Those are $150. Best shot is a used one from out west to minimize pitting. Not sure if the same setup was on Buick/ Pontiac. Even good used probably will set you back $150 or so.
Old Aug 31, 2021 | 07:40 AM
thanks alot for the info, i'll follow your search suggestion & hopefully i'll find a manual
Old Aug 31, 2021 | 10:24 AM
deaddds's Avatar
I’ve got several of the one design. No spares for the other design.
Old Aug 31, 2021 | 05:14 PM
does that mean you have both the left & rightside OE manual mirrors ?
Old Aug 31, 2021 | 07:33 PM
deaddds's Avatar
I definately have the right side manual but havent looked to see if i have the matching left side manual. Your remote left is certainly more useful unless its broken and then you will have the door panel toggle hanging.
Old Sep 3, 2021 | 11:41 AM
deaddds's Avatar
This is the rh mirror.
Old Sep 3, 2021 | 06:18 PM
ok i see the difference, my ride wouldnt look right with vastly mismatched mirrors, i did see a pair of remote olds mirrors from a 1980 olds 98 on e-bay with no part number listed with them, dont know if the base on them is tilted at the right angle for a 71 delta, the right side manual mirror i have sits wayyyyy to close to the door window causing the mirror to have to be tilted outside its enclosure just to be aimed towards the rear of the car & i dont wanna risk buying 2 more mirrors like that but do keep me in mind if you run across the mirror i need, thx
droptop70
Apr 12, 2020 11:05 AM
DrOlds72
Aug 2, 2019 06:24 PM
snail
Mar 31, 2017 03:24 AM
mmurphy77
Jan 14, 2015 12:35 PM
66-3X2 442
Jul 14, 2011 06:28 PM
