Wheel hubs for 1966 Dynamic
Old Oct 27, 2017 | 09:55 AM
king_doodle's Avatar
Hello Olds friends. Does anybody know if these wheel hubs would work for a 1966 Dynamic?--
https://www.opgi.com/cutlass/CH30556/
If not, do you know a source for 66 B-body wheel hubs?
Thanks a million,
Craig
Old Oct 27, 2017 | 11:19 AM
Thanks a million,
Craig
Not even close. Those are A-body hubs with the 5 x 4.75" bolt pattern. The Dynamic has a 5 x 5" bolt pattern. Wheel bearings are different also. The A-body hubs will fit a 1966 Jetstar 88, which uses the A-body bolt pattern, but not the other B-body cars. I'm not aware of anyone selling replacement hubs. No, Impala parts do NOT fit.
You have to really try to hurt the hubs. What's wrong that new studs or bearings and races can't fix?
Old Oct 27, 2017 | 11:48 AM
Thanks for your response, Joe. When I got my Cragar SS wheels a couple of weeks ago, the dudes at the tire place discovered balance weights welded onto the wheel hubs in front (and onto the backing plate in back). They knocked 'em off when a chisel and hammer so the wheels would go on flush. Now there's a little bit of shimmy in the ride at some speeds. So....I figured I'd just try to find nice machined wheel studs that didn't need any balancing.
Old Oct 27, 2017 | 12:03 PM
Sounds like the tire store's problem to fix. In any case, the right answer is to balance the wheels and tires on the car. Of course, the tire store is unlikely to have that equipment any more.
Old Oct 27, 2017 | 02:23 PM
ROCKETMAN269V's Avatar
.....discovered balance weights welded onto the wheel hubs in front (and onto the backing plate in back)........
If, by dumb luck, you still have the old weights and can identify where they came off of, there is a way to get the balance pretty darn close. You would have to add a smaller weight out toward the outside diameter of the wheels. The distance from the center of the hub x the old weight (inch/ounces) would be divided by the distance to the new weight location. For example: a 3 oz. weight, 4" from the center, would be 12 in/oz. If the weights that they are placing on your new wheels are at 7.5", you would add 12/7.5, or 1.6 oz. The weights would have to be in the same direction, radially, as the original weights. It works.
Old Oct 27, 2017 | 10:59 PM
Rocketman269V, thanks a lot. Great advice.
Old Oct 28, 2017 | 06:06 AM
I'm confused here. First, there are no balance weights welded to the hub. Any weights would be welded to the DRUM. Second, there were certainly no weights welded to "the backing plate" on the rear. Are you SURE you know what you are asking for?
Weights on the drum would look like this:
Old Oct 28, 2017 | 09:40 AM
Joe: No, I don't know what I'm asking about. Honestly. I don't know the name of all these parts. To add to the confusion, I've seen contradictory names used for the same thing, and local people I talk to don't know a coil from a condenser. Thus, my inconsistent use of terminology. I'm a fast learner though, and I appreciate your kind assistance. One day I hope to be a Joe.
The lugs/drums/hubs/whatever are now covered by the Cragar SS wheels, but you can see what I'm talking about in the 2 photos. The arrows point to the places where the weights were removed. In the photo showing 2 arrows, there were actually 3 weights removed, but you can't see the mark for the middle weight.
This one had 3 weights on it
This one had 1 weight on it
Old Oct 28, 2017 | 09:51 AM
That's the brake drum, as in the photo I posted above. Again, I question the quality of the work from this shop if they did that. The weights are there for a reason. Removing them will cause imbalance. If they removed the weights, the need to balance the wheels on the car to compensate for the loss of balance. This is their responsibility, especially if they knocked the weights off without your approval.
Old Oct 28, 2017 | 09:52 AM
By the way, it they just beat the hell out of those weights to knock them off, there's also a chance that they bent the drums. What morons.
Old Oct 28, 2017 | 10:14 AM
The quandary was that the wheels would not fit onto the car with the weights in place. The Cragars wouldn't lay flush with them in the way. So, it was either remove them or not have wheels. Should they have balanced the new wheels? Yes.
My inclination now is to find a couple of drums that don't require any kind of balancing. I suspect that will be difficult.
Old Oct 28, 2017 | 10:22 AM
You suspect correctly. Replacement drums for the 65-70 cars are nearly non-existent.
Old Oct 28, 2017 | 10:23 AM
In that case....maybe it's time to try a front disc brake conversion.
Old Oct 28, 2017 | 10:27 AM
Hopefully those Cragars will clear the calipers...
I'm surprised you have so much trouble with these wheels. The American Racing TTOs I put on my 67 D88 fit with no drama at all.
Old Oct 28, 2017 | 10:31 AM
No drama, just learning opportunities.
Old Oct 28, 2017 | 01:50 PM
It's too bad that you're not closer to me. I have a Hunter, "on the car" high speed wheel balancer.
Old Oct 28, 2017 | 03:19 PM
I would think somewhere in GA someone has an on car tire balance machine. If you still have the weights they knocked off you can have them welded back on and use a thin spacer to off set the wheels.
Old Oct 28, 2017 | 10:06 PM
Rocketman: I've heard of those Hunter dynamic balancers. What a great tool that must be. If I were closer I would definitely come by with some beers and we'd balance the heck out of it.
Oldcutlass: Yes, I'll probably find a shop with a dynamic balancer of some sort. Those weights are long gone, though.
--> Here's an idea. I may just go to Harbor Freight and get one of those bubble balancers. Use it for the wheels & tires first, and then for the drums. It will be interesting to see what kind of results I get.
Old Oct 28, 2017 | 10:29 PM
Here's an interesting article about wheel balancing from the July 1966 issue of Popular Mechanics. Pretty cool. The cover shows my next car.
Old Oct 29, 2017 | 08:55 PM
oldolds88's Avatar
I have good used drums for 65 olds 88 and 68 88 if these will work frt and rear, will need turning, but very useable. rob
Her69olds
Brakes/Hydraulic Systems
Mar 11, 2015 06:05 PM
aholiday
Jan 14, 2015 04:40 PM
71RadioflyerVista
Wheels and Tires
Dec 17, 2014 12:53 PM
costpenn
Feb 22, 2013 07:29 AM
CJR
Drivetrain/Differentials
Sep 16, 2009 12:19 PM
