Water Pump Pulley (1953 88)
Welcome aboard.
I'm sure one of the 'lost in the 50's' guys will chime in. By any chance does it look like this? Olds Water Pump Pulley - eBay
I just did a web search and found a lot of 1953 Olds 88's at Desert Valley Auto Parts . I only used the 1953 Olds 88 as a search, but I'm sure that the same pulley was used from 1949-1956 on 88's and 98's, which they seem to have a fair number of. Maybe you could check with them? Their on line ad says the cars are being parted and may have your desired pulley.
Thanks for the tip Allan.
Looking today I realized it's obviously not an original pulley as an a/c was added to the car, hence the 2 grooves. I have not removed it yet, but can I assume there might be a way to identify it once I get it off and inspect it?
It should have letters stamped into it. Is the pulley from a much later year? If so, you might be able to measure the 'bell' on the offset and use a more modern pulley.
