Water Pump Pulley (1953 88)
Old Apr 18, 2014 | 05:24 PM
Checker's Avatar
Sorry to make this my first post, but I am looking for a fan pulley for a 53 88
Old Apr 18, 2014 | 09:23 PM
Welcome aboard.
I'm sure one of the 'lost in the 50's' guys will chime in. By any chance does it look like this? Olds Water Pump Pulley - eBay
Old Apr 19, 2014 | 05:44 AM
Checker's Avatar
Thanks for the reply. I did see this one but I am in need of a two groove pulley. I have done a pretty exhaustive search with no luck, I just hope it's a matter of not knowing where to look(?).
Old Apr 19, 2014 | 12:41 PM
I just did a web search and found a lot of 1953 Olds 88's at Desert Valley Auto Parts . I only used the 1953 Olds 88 as a search, but I'm sure that the same pulley was used from 1949-1956 on 88's and 98's, which they seem to have a fair number of. Maybe you could check with them? Their on line ad says the cars are being parted and may have your desired pulley.
Old Apr 19, 2014 | 04:25 PM
Checker's Avatar
Thanks for the tip Allan.
Looking today I realized it's obviously not an original pulley as an a/c was added to the car, hence the 2 grooves. I have not removed it yet, but can I assume there might be a way to identify it once I get it off and inspect it?
Old Apr 19, 2014 | 04:43 PM
It should have letters stamped into it. Is the pulley from a much later year? If so, you might be able to measure the 'bell' on the offset and use a more modern pulley.
Old Apr 19, 2014 | 06:05 PM
Threejdsolds's Avatar
I have numerous 50's (including a 1953) and early 60's water pump pulleys. If you measure the diameter and depth of your pulley I can probably match yours. John
Old Apr 19, 2014 | 08:11 PM
Checker's Avatar
It is still on the car so it's nearly impossible to get an accurate measurement. Guess is 3 3/4 deep & 6ish width.
Hope to get it off tomorrow or Monday. Thanks.
Old Apr 19, 2014 | 08:15 PM
I LOVE IT! C.O. comes through again!
sshriber
Feb 25, 2012 07:36 PM
ScottMHoffman
Nov 2, 2009 09:20 AM
longboardguy
Jun 25, 2009 04:48 PM
72Ctlss
Jun 23, 2009 03:12 PM
olds4life
Oct 10, 2008 07:28 PM
