WANTED: Shift indicator Column Bracket
Shift indicator bracket needed.....
Hi. Trying to finish up the Cutlass and realized the PO bent a paper clip and hooked it into the column with no bracket. No wonder why it never worked. Does anyone have one available for sale, with or without the link, which I think is available. Any help would be much appreciated before I'm forced to fabricate one.
Thanks,
Bob
Thanks,
Bob
I’m assuming you’re referring to the small clip/bracket which screws into the steering column and contains the hole for the mounting screw or do you need the actual metal linkage which attaches to the indicator and the small metal clip?
Hi. Trying to finish up the Cutlass and realized the PO bent a paper clip and hooked it into the column with no bracket. It's the speed clip type extension bracket that sits in the elongated slot on the column, which holds the stiff wire that goes up to the speedo where the indicator is. No wonder why it never worked. Does anyone have one available for sale, with or without the wire link, which I think is available. Any help would be much appreciated before I'm forced to fabricate one.
Thanks,
Bob
Moved to Wanted......
Thanks,
Bob
