WANTED: Shift indicator Column Bracket
Old Sep 10, 2023 | 08:49 AM
1972 Supreme's Avatar
Shift indicator bracket needed.....
Hi. Trying to finish up the Cutlass and realized the PO bent a paper clip and hooked it into the column with no bracket. No wonder why it never worked. Does anyone have one available for sale, with or without the link, which I think is available. Any help would be much appreciated before I'm forced to fabricate one.
Thanks,
Bob
Old Sep 10, 2023 | 10:01 AM
Sorry, not following. You referring to the steering column shift indicator?
Old Sep 10, 2023 | 10:07 AM
I’m assuming you’re referring to the small clip/bracket which screws into the steering column and contains the hole for the mounting screw or do you need the actual metal linkage which attaches to the indicator and the small metal clip?
Old Sep 10, 2023 | 10:09 AM
In any case you’ll most likely find one from one of the members. Suggest you create a post in the Classifieds>Parts Wanted forum.
Old Sep 10, 2023 | 01:16 PM
The speed clip type extension bracket that sits in the elongated slot on the column, which holds the stiff wire that goes up to the speedo where the indicator is. Thanks
Old Sep 10, 2023 | 01:23 PM
Hi. Trying to finish up the Cutlass and realized the PO bent a paper clip and hooked it into the column with no bracket. It's the speed clip type extension bracket that sits in the elongated slot on the column, which holds the stiff wire that goes up to the speedo where the indicator is. No wonder why it never worked. Does anyone have one available for sale, with or without the wire link, which I think is available. Any help would be much appreciated before I'm forced to fabricate one.
Thanks,
Bob
Moved to Wanted......
Old Sep 10, 2023 | 01:49 PM
I moved/merged your 2 posts to parts wanted
Old Sep 10, 2023 | 02:30 PM
442crzy's Avatar
PM sent
ROCKETMAN269V
Apr 4, 2026 07:36 AM
shiftbyear
Jan 3, 2021 09:28 AM
72455
Oct 16, 2019 06:59 AM
BOOWAH
Oct 18, 2010 06:11 AM
