Wanted 66-70 Toronado 15x6 rims
Need 3 ...will take a complete set of 4 or whatever you have! Must be usable...
John
jpravato@hughes.net
John
jpravato@hughes.net
Are the rims from a 72 Eldorado the same? If they are, I think I might be able to help. mail me if you can use them.
Greg
mrolds88
drhotwheels@mybluelight.com
Greg
mrolds88
What year do you want them for? there are differences. 1966 all and 1967 drum brake use the same wheel, then 1967 disc brake and all 68-70 use the same wheel. Difference is in the trim ring area and valve stems. 71-78 Toro and Eldo wheels will work but not available chromed and the brake vent holes are considerably different from earlier cars.
If you need rims for drum brake cars, I have a dozen or so. One set of 5 chrome ones the rest plain steel. The chrome ones are rough as the car sat outside for some time except for the one that was in the trunk which is pretty good in the areas that will show once the trim rings are on and the center cap.
