Hello everyone, I need a drivers side door for a 65 and or a 64 Olds Cutlass 442 hard top. Also a 64 Cutlass door will also work. Please no severe rust, have that now. Please call Jerry @ 248-602-7855, or respond to this thread, thank you.
Hi Chris, I called and emailed the guy. I haven't heard anything back. The door looks good from the photo, at least from the view. Thanks for the help, Jerry.
Scott Winn oldspackrat has a set from a 64 convertible from my under standing they are the same as a holiday coupe hard top or check with John 2blu442 shipping maybe the down fall but I know scores were pretty nice
Jerry, I I have a good one out in Oregon. Are you needing just the bare door shell or do you need the glass and internal parts too? An empty door would be much cheaper to ship. Have you checked with oldspackrat yet? He's in Indiana and purchased a barnfull of 1964-65 Cutlass parts last year. John
Hi Jerry
I can't send photos through PM's so here's some picture, I can get more or take close-ups of any areas you'd like. There are signs of bondo on the skin, but looking inside the door I don't see any large dents so I suspect its a thin layer. I'm not seeing any cancer type rust, I removed the door seal from the bottom corners which seems to be the most common rust places I've found on doors. There's also an extra hole by the door lock... not sure what that was for but it would need patched. And one crease that wanders across the lower part of the door. This door came off a 1964 Cutlass and looks to have had the trim holes filled with bondo. John
