Wanted for 1984 Delta 88 coupe left upper door hinge
Old Jun 28, 2024 | 05:13 AM
jmcghee's Avatar
Need a good used or N.O.S left upper door hinge. For a 1984 Delta 88 coupe. P/N 20095425, used on every 1982-1990 B and C-body car built by GM. Also used on the 1980-81 E-body cars.
Old Jun 28, 2024 | 06:23 AM
69HO43's Avatar
Just a note, it can be R or L as the same p/n upper hinge is used on either side. So it can be a passenger upper as well. Just another source.
Old Jun 28, 2024 | 07:05 AM
newmexguy's Avatar
PM sent. Dave S.
Old Jun 30, 2024 | 10:18 AM
jmcghee's Avatar
bad info?
I
This is the left hinge
right hinge
either I have the wronge part number. 0r 68HO43 s info is wrong more research to follow
Old Jun 30, 2024 | 10:58 AM
jmcghee's Avatar
That is the wrong number, for what I need. Best i can tell from the 'net', that is the door side of a hinge, that does not fit an 84 Delata 88 coupe. I will have to get my parts books, out of storage to get the correct number. Visual inpsection of my hinge, says that only parts that are the same, side to side are, pins and bushings. Big thanks to all that have replyed. You brought to my attention that I was looking for the wrong number. I am looking for a complete used assembly. Or N.O.S. pieces to assemble one. again thanks Guys
Old Jun 30, 2024 | 11:05 AM
69HO43's Avatar
Originally Posted by jmcghee
I
right hinge
Apologies. Wouldn't be the first time the parts info is wrong. If it were a G-body, I'd be able to be of more assistance, as I know for sure the lower hinges are the same on both sides for a 2-door, but these bigger-bodied ladies sometimes defy the parts books.
I guess the bigger question is...what's the p/n for the RH upper on your car??? GM p/n's 20095426 and 20095424 don't exist that I can find, so if you blow the upper right one you're in for a search.
Old Jun 30, 2024 | 11:24 AM
69HO43's Avatar
Figured it out. Yeah, TWO pieces per upper hinge. Door side uses that single part number for either side, 20095425
Driver door body side uses this one.
Called SHIM or STRAP in the book. What a PITA.
Passenger side body side uses this part.
Old Jul 2, 2024 | 01:47 PM
jmcghee's Avatar
The parts book is a missprint. Visual inspection, of the hinges confirms, the door side is not the same for both sides.
postsedan
Jul 3, 2024 05:16 PM
jmcghee
Jan 15, 2024 06:26 AM
Mred355
Dec 22, 2013 07:33 PM
My442
Dec 3, 2012 07:18 AM
fdwheelman
Mar 24, 2010 08:35 PM
