Wanted: 1960 rocker arm shaft bracket (with anchor pin) 371
I'm looking for 2 rocker arm shaft brackets in good condition. I need the ones with the anchor pin (see attachment).
1960 oldsmobile / 371
thanks
thanks
Fusick has them for thru 1958. I guess there was a change in 1959 and they don't list them. Her is their link.
http://www.fusick.com/catfile/Catalog%20560.pdf
You might try Kantor. They have the complete rocker shaft assembly. Not cheap. Here is their link.
http://www.kanter.com///productdetai...Cat=32&Prc=365
@redoldsman thanks for your help
I got in touch with fusick and us parts supply already before but they only offer (like you said) the ones up to 1958.
The ones for 1960 are different and as I have already a brand new pair of shafts and a set of new rocker arms I would only need the 2 brackets with the anchor pin. I will try and see if Kanter maybe sells them seperately.
Might have some luck here. http://rossracingengines.com/
