Wanted 1/2" factory diesel head bolts
Old Jan 26, 2017 | 06:13 AM
442Fred's Avatar
I am in need of factory 1/2" head bolts from late 70's Diesel engines especially the accessory stud need a total of three of them in good condition.
Thanks Fred
Old Jan 26, 2017 | 07:49 AM
jensenracing77's Avatar
I can't remember one with the accessory stud on it? I believe I have some with the little hole in the top for the sensor but don't think they started that till 81 or 82? I have a bucket of bolts and parts from my dads last diesel, I will look and see if there are any with the stud on it. I think the head bolts were part of the problem with the diesel head gaskets, Are you sure you want to run stock ones? It has been to long since I was messing with the diesels but I thought the 82 had upgraded head bolts.
Old Jan 26, 2017 | 07:58 AM
Are the diesel motor head bolts different from the 1/2" head bolts used on every 1977-1990 Olds V8? If they are the same (and I suspect that they are), then any 307 is a donor.
Old Jan 26, 2017 | 10:20 AM
rustyroger's Avatar
'87 Delta 88 Royale
The torque settings for diesel engines was significantly more than for gas engines of the same timeline.
Also GM issued a bulletin stating that bolts should always be replaced, never re-used.
So I think Fred should look out some oe quality new bolts.
Roger.
Old Jan 26, 2017 | 10:55 AM
Roger.
The 1982 Parts Book shows the same P/N head bolts for the 307 and the 350 Diesel.
P/N 22510579 for the 4.30" long bolts
P/N 22510580 for the 3.10" long bolts
P/N 22510582 for the 3.10" long bolts with accessory stud
P/N 22510585 for the 4.30" long bolts with accessory stud
P/N 22510583 for the bolt tapped for the temp sensor
Is this for a diesel application, or a DX-based gas engine? If the latter, I'd have no qualms about reusing bolts.
Old Jan 26, 2017 | 01:45 PM
442Fred's Avatar
Guys what I am trying to do is find the 1/2 accessory bolts for one of my aluminum 455's we are building. It had batten heads on it with hex bolts so worst case is I just need 3 accessory bolts best case is a complete set.
So it will be a gas motor roughly 10:1
If I can't find any here then I will hit the local yards to see what I can find. I appreciate any help.
Old Jan 26, 2017 | 02:09 PM
wr1970's Avatar
I am just thinking out loud. Why couldn't the op use a new stud / grade 8 bolt. Ace hardware,Tractor supply ect.
Old Jan 26, 2017 | 02:14 PM
Because head bolts have a specific shape to ensure proper clamping. You won't find anything like this in a hardware store:
More to the point, he specifically needs the accessory bolts with the stud on the head.
Old Jan 26, 2017 | 02:27 PM
wr1970's Avatar
Thanks Joe for the reply get what you mean. I need to go check and see if i saved mine. I think i threw mine away. I read that a part about not reusing them a few years ago.
Old Jan 26, 2017 | 03:12 PM
If you search on those part numbers, you find new ones on ebay.
Old Jan 26, 2017 | 04:07 PM
442Fred's Avatar
Thanks Joe this was easier than I had expected they are still available through GM too.
Old Jan 26, 2017 | 04:10 PM
Kewl. There are quite a few older parts still in the system if you have the P/N to help search for them.
stanzaschance
Jul 28, 2015 06:38 AM
nolabigdawg
Oct 25, 2014 11:50 AM
EightballZ
Mar 24, 2014 05:03 PM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
