w31 fuel line
Old Sep 2, 2020 | 01:35 AM
Orlando 1's Avatar
O'smobile
w31 fuel line
I need the hard line from the pump to the carb for an almost factory 4bbl setup. Using the original pump and carb with an Edelbrock Performer intake.
Old Sep 4, 2020 | 09:58 PM
v8al's Avatar
Registered Olds Owner
Hi - I have this one: https://www.yearone.com/Product/1964...lass-442/rs441
Let me know if you want pics or measurements.
I am in the LA area also.
Al
Old Sep 6, 2020 | 01:03 PM
Orlando 1's Avatar
O'smobile
Al
Can I see a shot of it installed? Thanks for the reply.
Old Sep 9, 2020 | 10:54 PM
v8al's Avatar
I never installed/used it. I ended up going with a Quickfuel/Holley setup.
Have attached an overall shot of the line and how I *think* this line is routed on a small block.
Al
Old Sep 10, 2020 | 09:11 PM
Gerald Nickels's Avatar
That's a 455 engine not a 350 Olds it might be to tall when installed on a 350 Olds.
Old Sep 10, 2020 | 09:47 PM
v8al's Avatar
Curious how did you identify it as a 455 engine? Perhaps someone likes big block blue better than small block gold?
Old Sep 11, 2020 | 04:35 AM
ROCKETMAN269V's Avatar
Curious how did you identify it as a 455 engine?...........
The intake manifold sits up ~1" higher than the surface behind the timing cover on big blocks. Also, the hose between the thermostat housing nipple and water pump is ~1" longer.
Old Sep 11, 2020 | 11:00 PM
v8al's Avatar
Cool - I think judging the intake manifold height would be easier to see in person then via a picture.
In this case though it is a 350.
Old Sep 12, 2020 | 01:53 AM
Orlando 1's Avatar
O'smobile
Cool pic, thank you. Just curious, why the regulator?
Old Sep 12, 2020 | 09:20 AM
70Post's Avatar
The original steel fuel line (pump to carb) routes around the OTHER SIDE (the P side) of the thermo housing if it matters.
Old Sep 12, 2020 | 10:36 AM
v8al's Avatar
No regulator just a fuel pressure gauge.
Old Sep 21, 2020 | 02:08 PM
Orlando 1's Avatar
O'smobile
Part Number?
Al
Thanks for the photo and measurement. Interesting how it goes around the drivers side of the water neck. it is well-formed and all. I'm curious about the fitting on the pump side. Is it horizontal or at a 45 degree? It looks to be tilted up about 45 degrees but its hard tell for sure. Is that 3 line pump? Mine is a 2 line and the fitting comes out at zero degrees (or horizontal).
Thanks for all your fuel line info.
SSMonte350
Dec 3, 2013 02:13 AM
Elephant_Engine_Ernie
Oct 10, 2013 02:24 PM
arodenhiser
Nov 9, 2011 05:54 PM
ziff396
Oct 20, 2011 07:08 AM
boondocker
Aug 13, 2011 10:53 AM
