Trunk Striker
Hey Ken,
You mean there's nothing in the boneyards around you??? Just looked at mine to verify what you want. It's held in by 2 3/8" bolts right? It should be the same from 68-77 IIRC so you should have lots of options. If no one gets back to you, check with (John) 2blu442, (Eric) Jensenracing77, or Oldspackrat. The last 2 are closer to you. I believe they are around the Ohio area. Have you talked to Craig (66ninetyeightLS)? He might know someone in your area with the part.
Just so everyone knows what you want ( I hope this is right) here are pics of what I think you are looking for.
The little square dude in the middle
attached by these two bolts
Ken? lol None of the boneyards have older stuff around me anymore that i know of. Thnx for posting the pics, that's exactly the part i am looking for. I have misplaced mine and i can't find it anywhere!
There's another guy on this forum with a name a lot like yours (check the community - his name is oldzy and he's in Hamilton). Check this link, the guy is in your area and seems reasonable: http://ontario.kijiji.ca/c-ViewAd?Ad...n=email_alerts I think some of his prices are high, but most are reasonable and you can pick it up so shipping is a no brainer. He definitely has the part you're looking for though.
Sometimes the striker and the cage surrounding it are not squared up like the one shown in the pic from Allan. The one on my trunk is really misaligned but the trunk closes as it should. I've seen others at shows that were also tilted left or right. Any idea why the cage would be off-center as I've described?
I'll probably play with the latching system to make the trunk close nicely. Hate having to slam it. If you look closely at the pic I took it looks like there is something binding on the left side. Also need to pull the weather strip out a bit and clean up that surface rust. Don't know where it came from but it wasn't there a couple years ago.... Some wax should do the trick.
Is the latch area supposed to be black or the same color as the car. As you can see, mine got painted when the car was done, then it got some of the splatter coat that finishes the trunk on it. Personally, I think it would look a lot nicer in a satin black.
