trans throttle control (kick-down?) switch
Old Jul 27, 2004 | 12:55 PM
salisbury99's Avatar
Post
I need a part for my 1967 Olds 98 425. 1965 thru 1967 Olds used this switch. My owner's
manual calls the part an "auto. trans. throttle switch". Someone else
called it a trans-throttle switch. It's located
under the hood, near the firewall, mounted on a bracket. It has linkage
from the carburetor, and linkage from the firewall (gas pedal), linkage
from the cruise control, and linkage from the transmission, all hooked up
to it. It has a square shape (I've seen others that were round), and It
has three wire connected to it (on the opposite side of linkage hookups).
Two bolts (on the bottom) attach the switch assembly to a bracket. I can email photos of this part.
If you can't help, do you know someone that may?
Thanks,
Tom Salisbury
salisbury99@juno.com
[ July 27, 2004: Message edited by: salisbury99 ]</p>
Old Dec 28, 2007 | 04:58 AM
Lazy's Avatar
Large Member
Question U still need 1?
Does it look like this?
Old Jul 5, 2008 | 05:26 PM
cliff's Avatar
where do you get one of those?
mat1227
Oct 16, 2013 03:41 PM
66 Olznut
Apr 22, 2013 08:32 PM
oldspackrat
Mar 30, 2013 04:57 AM
cutlassjoe
Oct 14, 2011 04:41 PM
highlander
Apr 16, 2010 10:28 AM
