Tailgate window lift motor
Do you have the old one? I spent weeks looking for a motor for a customer's 66 Caprice Wagon and ended up getting the old one rebuilt for about a hundred bucks. I have the info.
Frank
Frank
The rear lift motor is the same as one side door motor. I can't remember but I think it is the same as the driver side? I do have a used motor from the back of a 70 Vista that works. $40 shipped. They are the same from around 65 to mid 70s.
I've had a few wagons, I get the window motors rebuilt for about $50-60 local to me, takes a couple weeks if it needs parts ordered.
Now this is a tidbit I got from one of these forums, don't remember which one, and I have not tried it. The rear window motor for a wagon is the same as the rear window motor for an 80s suburban, GM part #5045610. I crossed it at AutoZone to a Cardone #42-14.
Finally, be careful in there. On the 66&7 which I have worked on you must drill a hole and put a screw in to keep the spring in check so the motor can be removed safely. I found the instructions in the body manual, likely available on the Wild About Cars site.
Luck,
Luck,
I talked to these guys about the tailgate motor for my '67 Vista: www.windowmotor.com. They are in Margate Florida. They told me there are differences between door motors and tailgate motors. Said rebuild would be about $100 and take a week. Might want to talk to them also.
wyteon
Vista Cruiser & Wagons
November 30th, 2018 11:33 AM
197064buickspec
September 9th, 2013 08:55 PM
