Switch Pitch Torque Converter
Old May 4, 2018 | 02:43 PM
F-85 4-4-2's Avatar
Looking for a switch-pitch (aka variable pitch) torque converter for a '65 Jetaway aka Junkaway aka Super Turbine 300 transmission. A core is fine and dandy, especially if near Cleveland O-H-I-O.
Old May 4, 2018 | 03:22 PM
2blu442's Avatar
If you don't find one closer I've got several out in Oregon. But shipping may be as much as the purchase price! Just sharing this so you know as a back-up I've got one.
John
Old May 4, 2018 | 05:32 PM
RAG's Avatar
RAG
I have a few in NM to sell.
Old May 4, 2018 | 05:37 PM
F-85 4-4-2's Avatar
Oregon, New Mexico...getting closer to Ohio...
Old May 4, 2018 | 07:21 PM
66-3X2 442's Avatar
You might consider checking FATSCO for a rebuilt unit. Google is your friend or @ least that's what they say.
Old May 5, 2018 | 05:46 AM
X2 on Fatsco. I got a rebuilt switch pitch for my 67 Delta from them last fall. They do this as exchange, so you may have a problem, or at least a core charge, if you don't have one now.
Old May 5, 2018 | 07:29 AM
66luvr's Avatar
I have one in southern Ohio, Ironton, zip 45638. If you are interested send me a private message, we can get together on the telephone.
Mike
Old May 6, 2018 | 03:49 PM
george landis's Avatar
switch pitch convertor
What's wrong with Dacco-Detroit. Most trans shops on east coast use them. Switch pitch converters are $100 or so. Both 300 and 400 sizes. How much are Fatsco's?
Old May 6, 2018 | 03:56 PM
Originally Posted by george landis
how much are fatsco's?
$104
Old May 6, 2018 | 04:12 PM
White_Knuckles's Avatar
Hi, chiming in for any subject matter expert with these 300's that may have a clue where they may leak from? I restored switch pitch with a B&M switch armed on the throttle shaft to go off as the 4 bbl opens, Quite a kick from that baby! Anyway, I can't identify the leak source but have eliminated the pan gasket. Shops snort and giggle at it and say "you outta put a 350 in it". If they only knew the switch-pitch happiness. They pretty much say service isn't worthy. Seeing others keeping them alive makes me wonder. Are they worthy??
Old May 6, 2018 | 04:19 PM
Open your CSM to Chapter 7 and look at the exploded view of the ST300. Every gasket, seal, and plug is a possible leak source. That's not to be a smartass answer, just the truth. That doesn't count porosity of the case, by the way.
The list is lengthy.
Torque converter seal
Pump to case seal
Pan seal
Manual shift shaft seal
Speedo adapter seal
Speedo driven gear seal
Tailhousing to case seal
Output yoke seal
Inlet pressure fitting
Outlet pressure fitting
Pressure test ports
Electrical connector
Dipstick tube
Vent tube
Old May 6, 2018 | 05:13 PM
Yikes, and reassuring (sort of). Hoping for the "it's the fill stick o-ring as common". I have laid under that car staring at the bugger after a good rag down where she was sanitary. After a few minutes fluid appears in the rear pan seal and seems like it's the pan. Been there twice first a new rubber gasket and checked the tin for dished bolt holes. Same annoying slow leak followed by the black Permatex super space gasket goo. (The spendy right stuff). Nope, still a Leaky Pete. I've read others plagued by leaking with these as well. Thanks Joe. (back to the 350)
Old May 7, 2018 | 08:19 AM
F-85 4-4-2's Avatar
I've found a torque converter locally. Oh, and my tranny leaked in many of those places!
Old May 7, 2018 | 01:38 PM
Kennybill's Avatar
Just curious, you said you'd take a core. Were you going to get it refurbished and if so where? I'm near Warren, OH and I'm considering having an S/P converter looked at. Thanks
Old May 8, 2018 | 09:03 AM
Well guess they are prone to combo leaks then. Doh!
Old May 8, 2018 | 05:04 PM
F-85 4-4-2's Avatar
A local shop, Parma Transmission, cuts it open, rebuilds, and welds 'er closed.
hotrodpc
28
Feb 12, 2015 06:06 AM
Koda
19
Sep 7, 2013 11:36 PM
CroixDad
Mar 25, 2013 11:14 AM
jaysun
Apr 29, 2010 09:02 PM
coppertopgmc
Sep 17, 2007 08:28 PM
