serching for 1970 Oldsmobile intake manifold
I'm looking for a February or March, 1970 dated, 350 4 barrel, cast iron intake manifold, with no cracks, or welded places, all threaded holes needs to be in good condition, would like to see pictures! thanks in advance! Brian
Send me the numbers to look for and I will check the intake I have. Email direct dead@mchsi.com
Hello! it should be marked on the top of the intake with 404520 and on the underside there should be a date or a date code! it should not have a EGR valve! if you get a chance send some pictures! thanks Brian
not only does the intake need to have the casting number 404520, I would like to have it dated around 85, the date is behind the firing order, there is a little pad with 1, 2, 3 different numbers, my heads are dated 85, which means March 26 1970, I would like to have the date of the intake somewhere around that date. thanks! Brian
Actually no if you have a performer intake I definitely want it this guy is looking for a stock intake which will be available once I buy yours ya see
Ctls442
January 8th, 2018 06:03 AM
shamusj
December 18th, 2014 09:28 AM
Nickyloves442s
October 24th, 2012 04:55 PM
svnt442
July 17th, 2011 04:43 PM
