Rochester Dual Jet
Old Jun 9, 2014 | 05:03 PM
qdup's Avatar
Rochester Dual Jet
Hi all, I have a stock 350 in my car and it has a Q-jet installed that is in sad shape and am considering installing a Rochester Dual Jet carb. Would anyone be will to sell me a good one that is not in need of a rebuild? Thanks.
Old Jun 9, 2014 | 05:25 PM
Paladin31's Avatar
2BBl
I have a 2 barrel off of a 72 350 auto, everything moves freely and appears complete its dirty and I would definitely say it should have new gaskets & piston, to make it safe & new gas compatible. $20 plus shipping. Brett
Last edited by Paladin31; Jun 9, 2014 at 05:26 PM. Reason: I cannot even spell 'off' today...
Old Jun 9, 2014 | 06:18 PM
Originally Posted by Paladin31
I have a 2 barrel off of a 72 350 auto...
That's 2-Jet. It won't bolt up to his manifold, but an early DualJet will.
More importantly: If you want to swap carburetors, why not get another QuadraJet to swap in?
They're much easier to find.
Old Jun 9, 2014 | 07:17 PM
Octania's Avatar
Where does one find these carbs that don't need a rebuild?
Let alone the rare Dual-Jet?
I saw one at the boneyard last weekend, but I'd assume it needs to be gone thru.
Oh, oops, that is not the true faux 4-bbl, needs a special intake.
Old Jun 9, 2014 | 07:32 PM
Exactly. That's the later DualJet. Good luck finding one of the early ones with the QuadraJet size format.
Old Jun 9, 2014 | 07:34 PM
Paladin31's Avatar
Dual doesn't = 2?
I'll bite what time range were dual -jets in use, and why is it that they wouldn't be a Two jet ? Forgive my ignorance please
Old Jun 9, 2014 | 08:18 PM
Octania's Avatar
yah, fix my ignorance also
I am GUESSing first year of 260: 1977 or 1976?
Ck my INTAKES pix thread here for what intakes therefore what year range?
I actually have one of the faux 4-bbls somewhere
I think the carb man has an NOS one
I saw one recently on Feepay, made out of a real '68 442 carb 7028251, which really should be made back into a '68 442 carb.
aha
http://www.ebay.com/itm/Acdelco-12-9...896818&vxp=mtr
dirt cheap
when you are done it'll still be worth $$ as a 7028251 body
Old Jun 9, 2014 | 08:24 PM
Paladin31's Avatar
In-turd-esting, the vaunted powerhouse 260, Holy Grail of Marine anchors...sorry couldnt help myself. Thanks Chris, see you at H/C Saturday?
Old Jun 9, 2014 | 08:42 PM
Sugar Bear's Avatar
X2...why do you want to do this? Can your Q-jet be rebuilt? Disable or lockout the secondaries if you only want the small primaries to operate. If you tell us what your goal is we may be able to offer better suggestions.
Old Jun 9, 2014 | 10:52 PM
I don't know the exact numbers, but the 2-Jet (2GC), which was essentially half of a 4GC, was used by all GM divisions (maybe not Caddy) from roughly the late fifties through 1973 or '74.
The 2-Jet was an excellent carburetor, simple and durable, and did a good job, but was unable to meter fuel with the precision required for increasingly demanding emissions laws.
When the QuadraJet was introduced, it was a far superior design to the older 4GC, and was found to be able to meter fuel much more tightly, so in the mid-seventies, as new fuel economy requirements began to mandate smaller engines, the DualJet was designed as sort of a stop-gap, essentially comprising the primary half of a QuadraJet without the secondary half.
I believe it was introduced in 1976 as a carburetor that looked like a QuadraJet at a glance, and used the same intake manifold, but in fact had an "empty" back half.
After a year or two, a more purpose-built version was introduced that looked like Chris's picture, that did away with the "false back" and now required its own special intake manifold. This model lasted some time into the eighties.
While the 2-Jet is fairly ubiquitous, having been used on the majority of V-8s that GM produced in the sixties and into the seventies, the DualJet is much harder to find, mostly because they were not used on that many cars, and the cars and engines they were used on were, to a great extent, garbage, and were scrapped without pity.
Which is of course why we're wondering why the OP wants one.
Old Jun 10, 2014 | 04:07 AM
ROCKETMAN269V's Avatar
Smile Rochester Dual Jet
If he truly wants one, I have a very nice core that I was going to build for a customer that never showed up.
Old Jun 10, 2014 | 06:02 AM
qdup's Avatar
Dual Jet carb
Thanks guys for the reply's and offers. I am starting to question my idea of the 2 barrel too. I thought if I did rebuild a Dual Jet that it would be easier to do and I just wanted to try a 2 barrel for a change without having to change manifolds.
Old Jun 10, 2014 | 08:41 AM
You will get the same effect by simply locking out the secondaries on your Qjet.
The Dual Jet ONLY has the tiny Qjet primaries. A 2GC 2bbl has more flow than a Dual Jet. You will likely be sadly disappointed with a Dual Jet.
Old Jun 10, 2014 | 09:37 AM
Octania's Avatar
HAH there's one!
Great photos
with that, you could make a "four faux two"!
Old Jun 10, 2014 | 11:19 AM
qdup's Avatar
Dual Jet
Thanks again for that piece of info. Guess I will stick with a good Q-Jet.
Old Jun 12, 2014 | 12:20 AM
delta7388's Avatar
Get a re-manufactured Q-Jet from Holley at your local parts store -- just checked my receipts and I paid $208.99 for mine on June 8th 2004, so they might be a bit more now -- it's got more than 15,000 miles on it now atop my 355 CI Rocket - hasn't missed a lick --- Part #HOL 64-7255
Peace Out
Erik
CO53Super88
Jun 4, 2022 08:02 PM
oldsfever
Sep 27, 2010 09:35 AM
cargo442
Sep 19, 2010 05:19 PM
Beeterolds
Jun 28, 2008 09:44 AM
