Ridiculous Last Small Pieces Needed -72 Vert Coat Hook
Looking for a good used Black 72 Cutlass vert coat hook. Also need that little bar that bolts to the underside of the hood in spanning the hole that the latch grabs onto.
Scott, here's a pic of the coat hook I'm looking for as well the bottom of my hood where I think I'm missing something. I believe there is a little part that bolts in the middle of the square hole that the latch mounted on the core support hooks to.
There is nothing that goes in the square hole, that goes down over the latch mechanism on the radiator support. There is a little hook that is bolted in that other T shaped hole with the small round holes on each side of it. That is the secondary latch mechanism that you pull up on to raise the hood. I don't have any conv. coat hooks right now. I was in a yard yesterday that had a '71 skylark convertible, but I didn't know you needed one then.
Del70
September 30th, 2014 07:21 PM
RetroRanger
August 5th, 2014 05:37 AM
halfmoontrail
March 17th, 2013 10:28 AM
projectheaven
January 8th, 2012 09:17 AM
