Replacement Raditor for 1964 Cutlass Convertible
Looking for a replacement radiator for a 1964 Olds Cutlass 330 V8, auto, with no A/C.
Has 2 inch inlet/outlet on the drivers side and TOC connectors along the bottom.
Approximately:
20 7/16 inches high
25 7/16 inches wide
2 5/8 inches thick
2 inch inlet/outlet
...using a crappy cheap tape measure...
See attached picture.
Shipping to Sweetgrass, MT 59484
Anyone have a source?
Approximately:
20 7/16 inches high
25 7/16 inches wide
2 5/8 inches thick
2 inch inlet/outlet
Approximately:
20 7/16 inches high
25 7/16 inches wide
2 5/8 inches thick
2 inch inlet/outlet
Approximately:
20 7/16 inches high
25 7/16 inches wide
2 5/8 inches thick
2 inch inlet/outlet
Brother, Robski here you may have seen my 64 F-85 Pro touring build. I pulled the original rad out of the 64 had it complete rebuilt and had the bottom outlet moved to the passenger side, you will not find many drivers side water pumps around that are good. That said all I did is put water in the system to start the car and that's it. Its as good as it will get for a 64 Harrison rad. If you are interested PM me I live in the Dallas area. Need $150.00
Larrys'66
December 22nd, 2014 06:33 PM
64oldsf85cutlass
Body work
July 4th, 2014 07:06 AM
