Pcv valve related parts
Does anyone know where I can basically get the whole system, maybe a diagram or maybe atleast a list of everything I need. I am starting from scratch. My motor guy and I thought it would be smart to delete it during our new awesome engine build. Lol I’m eating a lot of crow here. Oh yeah it’s a 1971 Oldsmobile Cutlass 350. I have a fast system
Last edited by Powerm01; February 24th, 2022 at 11:06 PM. Reason: Adding information
Basically, you need a PCV valve, with a 3/8" hose connected to manifold vacuum. The valve would be installed into a grommet in one valve cover. In the other valve cover you would need a source of filtered air; either a breather or a hose to the bottom of your air cleaner.
That diagram is a bit confusing, especially if you're not familiar with the system. The "D" shaped grommet that they show in mid air would actually be in the opposite valve cover, along with the 6H filter assembly. The round hole in the 6H filter is where the molded rubber elbow is attached; a formed metal tube is inserted into the other end of the elbow and connects to another rubber elbow in the base of the air cleaner.
Awesome, all great information. I went with tall aluminum finned “Oldsmobile” signature emblem valve covers with just a breather system. I painted them black. No baffles. It is pretty but oil is an issue lol
so I wanna go with the PCV system. I like the tall black stock looking valve covers. Almost had a pair but they sold out. I need tall because I have a rockers. I guess I could just get the Chrome, scratch them up and paint them. I want to go with the stock look including grommets and all.
An Alternate Idea
The vent breather has internal mesh to knock out the increased oil mist from those covers, but the PCV would deal poorly with lack of a baffle.
To compensate, I put in a valley-mount PCV like the manual transmission W-30s and 442s had. This pulls from above the turkey tray where the large, quiet volume drops out oil mist before it gets to the PCV.
I got these parts as reproductions from Fusick.
This assumes you have a QuadraJet and a GM intake manifold. If you don't, you would have to make custom (probably longer) steel tubes to connect the breathers to the air cleaner body.
I assume you are asking about how to install the PCV. Your pipe plug goes into a carb runner. You need to go into the valley (left of that runner). I picked a flat spot over the valley, epoxied a thick aluminum collar there, and inserted a 1/2" OD steel tube with a ferrule soldered to the top.
That is exactly what you need, in addition to the PCV. You still need a PCV valve with a vacuum source to pull air through the breathers, exactly as VC455 described. If you use just the breathers, exhaust gases will exit the breathers and you’ll smell it while driving. The PCV / vacuum will pull air into the breathers and into the carb, where the gases will be burned so no smell or eye burning.
Yeah It would be a little different for me. I have an Edelbrock performer and a fast set up. I do like the Oldsmobile emblem valve covers that I have. They do look good but about two hours ago I ordered the tall black OEM looking valve covers. I think I’ll just use those and go with more of a factory set up. Might actually be less work than all that awesome fabricating you did. But it does look clean, you got rid of that big nasty hose. Definitely thanks for your input. I wish I thought about all this before the build lol.
Bee Saint Louis
September 17th, 2021 06:22 AM
