Olds307 Throttle bracket
I am in need of a throttle bracket from a late 80's Olds 307 with a Q-jet carb. I will be installing a 200-4R trans in my '72 442 convertible and would like to use OEM parts instead of the aftermarket kits. The bracket is attached using the rear carb mounting bolts and will look similar to the picture below; however, it will have 2 square mounting tabs, one for the throttle cable and another for the TV cable to the trans. Thanks!
Rodney
Rodney
cutlass1972s
July 6th, 2010 06:33 PM
