oem flexplate for 455
Old Feb 8, 2014 | 04:08 PM
72cuttys's Avatar
Need a OEM flexplate for when my motor goes to the machine shop to balance. Located in Harford County MD.
Old Feb 8, 2014 | 04:31 PM
Octania's Avatar
Should be super easy to procure.
You may wish to specify what the engine is... exactly.
Old Feb 8, 2014 | 05:14 PM
72cuttys's Avatar
1970 455 motor, factory crank.
Old Feb 8, 2014 | 07:16 PM
kevdog442's Avatar
Member
I've got one on eBay right now. Cheap. It's off of a 68 455.
Old Feb 8, 2014 | 08:14 PM
507OLDS's Avatar
I have some. $25.00 each. Price includes shipping to MD.
Old Feb 15, 2014 | 12:13 PM
ferndaleflyer's Avatar
Go to a parts store and get a new one. I had a motor built in Baltimore and the new flex plate was $60. Not worth the chance of messed up teeth on a used one----Mine was balanced at the "House of Balance".
Old Feb 15, 2014 | 12:58 PM
Octania's Avatar
I would take a used factory part with good teeth over something produced recently [almost certainly Chinese], any day. Over and over this lesson has been learned. Fit, function, finish, durability, hardness.... all can be wrong.
Old Feb 15, 2014 | 01:22 PM
nicks1966's Avatar
normally I agree that used factory parts are best, but last year I picked up a flexplate at Autozone of all places, FRA102 by pioneer. Made in the usa. Great piece very well made and at the time it was 29.99 in stock. looks like it's 39.99 now.
Old Feb 15, 2014 | 02:10 PM
Octania's Avatar
I see...
That kind of tips the balance towards the new part, as long as it fits properly.
SOME things are still made in the USA! YAY!
Old Feb 15, 2014 | 05:22 PM
Exactly----I am sure my race car with a ton of compression and a high torque starter is harder than a stock motor on a flex plate. I am not sure where mine come from but I have yet to have a failure.....on the other hand its hard to find a used flex plate with no wear on the teeth. But this is just my own opinion.
Old Feb 15, 2014 | 06:10 PM
507OLDS's Avatar
The first thing I check are the teeth. If any of them are damaged,it gets pitched. Then I check to see if it has been modified for something that was rebalanced for a rebuild. As long as everything checks out,and it is the same as it was when new,I keep it.
The one I shipped to you is like that. If you find something wrong with it,I will send another.
The question of whether to use a stock or aftermarket SFI piece,often gets debated when doing a performance build. In my opinion,your typical street/strip engines running under 6,000rpm will work just fine with an OEM flex plate. I had a new ATI flex plate,when the 507 was being built,but Travis was sure a stock piece would be fine,so I still have the ATI in the box,after all this time. I will use it in the 517.
csouth
Dec 7, 2012 04:53 AM
real57vetteguy
Aug 8, 2012 07:54 AM
olds455
May 17, 2010 04:43 PM
ctrain22
Jul 10, 2009 08:13 AM
1FSTLS1
May 10, 2008 09:40 AM
