O type gears
Correct for what? Yes, they are correct for installation on a factory 3.08-3.23 carrier, but not correct for a factory 3.42 carrier.
Here's some O-Type info that Brian Trick posted many years ago. This shows there are essentially three series of carriers and gears are made specifically to fit a particular series.
O-Type 12 Bolt
Here is a list of the posi units & what gears they will fit:
#673 = 2.56 & 2.78 ratios, 28 spline
#671 = 3.08 & 3.23 ratios, 28 spline
#588 = 3.42 & anything numerically higher, 28 spline
#672 = 3.42 & anything numerically higher, 31 spline
***The 31 spline axles were offered in late 67-68 OAI cars only.
O-Type 12 Bolt
3.42s
Read the above posts again.
Your 673 carrier will not work with factory 3.42s or with the Richmond gears either.
I believe those summit gears will only work with a 671 carrier? Not totally sure but Brian or Monzaz will tell you for certain.
heres your summit gear description;
Richmond Gear 49-0049-1 - Richmond Gear Ring and Pinion Sets
Click here for more information about Richmond Gear 49-0049-1 - Richmond Gear Ring and Pinion Sets
$30.00 Summit Bucks
Free Shipping
Gear, Ring and Pinion, 3.42:1 Ratio, GM, 8.5 in., O Axle, 10-Bolt, 3 Series, Set
says right there in last line -- 3 series --- that specifically means a 588 or 672 carrier!
$30.00 Summit Bucks
Free Shipping
I think that is incorrect. The Richmond gears are made to fit the 671 carrier. I have no idea what "3 series" means for the O-Type as there are 3.xx gears for both the 671 and 588/672 carriers.
https://classicoldsmobile.com/forums...ar-spacer.html
https://classicoldsmobile.com/forums...swap-help.html
Well, if we call the 673 carrier (for 2.56-278 gears) the "2 series" then the next logical step is the 3.08-3.23 are the "3 series" which leaves the 3.42/3.91/4.33/4.66 as the "4 series".
So much easier to just say which factory gear range it covers and leave the ambiguous "series" nomenclature out of the conversation.
monzaz
January 4th, 2017 07:35 PM
monzaz
Drivetrain/Differentials
August 7th, 2014 11:12 AM
L77F85
16
November 29th, 2013 06:19 AM
