Need Valve Covers for 5.0 307 1984 riviera
Old Sep 12, 2021 | 08:08 AM
84riviera's Avatar
looking for valve covers for 5.0 307 1984 buick riviera
feel free to text anytime 808-228-9940
located currently in Oklahoma
Old Sep 13, 2021 | 06:21 AM
newmexguy's Avatar
84 Eldorado
There’s a very clean ‘84 Cadillac Eldorado in the pick a part I frequent. Have not looked at engine closely, perhaps it’s the same 5.0 L since it’s a sister E body. It’s behind the ‘70 Catalina in this picture.
Dave S southern New Mexico
Old Sep 13, 2021 | 08:10 AM
69HO43's Avatar
Technically you could use any stock "modern" Olds V8 valve covers for the most part. The 307 used a 5 hole valve cover on each side, but as long as you seal up the extra holes, you could use older style 10 bolt covers if you had to. GM used gasket maker goop for sealing the valve covers to the heads. The stuff gets old and cracks and leaks. If you're not worried about originality, make sure any valve cover you get is straight along the valve cover bolt holes (straighten as necessary)and use a good, quality aftermarket valve cover gasket. Over-crunching down the bolts doesn't do much for sealing and only makes any leaks worse.
If you can get the 5 hole covers, you'll be miles ahead, though. Otherwise, that's 10 extra holes to cover up and 10 extra chances for leaks. JMO.
Dogge
Feb 25, 2020 07:57 AM
edzolz
Jun 16, 2016 02:23 PM
tru-blue 442
Apr 10, 2016 11:03 AM
Stevec
Jan 23, 2014 03:09 PM
slaughter442
Feb 4, 2013 04:08 PM
