Need: TH350 or Jetaway driveshaft 67 442
FYI, the 442 had a solid tube driveshaft and not 2 piece with rubber connector. The Cutlass had the 2 piece shaft. Will work fine but not recommended for racing. I have a couple from Cutlasses if interested. Both had Jetaway. NJ
Thanks for the additional info.
Putting a 2004r into a 67, and was told I needed the longer driveshaft in the shift from the TH400 to the 2004r..
Hadn't added the additional about the solid tube, etc.
Thanks,
Thanks,
I have a 71 Olds 8.5 rear, and still using the stock 442 shaft as far as I know.
Thanks and let me know either through email or a PM on whether you have something.
NOTE: Also just saw that supposedly a 4 speed shaft would fit and be solid as well.
So anyone got one of THOSE laying around that they don't need?
Thanks,
Thanks,
Last edited by Flye; March 1st, 2011 at 06:02 PM. Reason: adding note about 4 spd should work
costpenn
April 11th, 2012 07:25 PM
