Need: TH350 or Jetaway driveshaft 67 442
Old Feb 27, 2011 | 04:55 PM
Flye's Avatar
I need a GOOD driveshaft to fit a 67 2 door (442), TH350 or Jetaway evidently.
Thanks and let me know.
Thanks.
(in Virginia)
Old Feb 27, 2011 | 05:01 PM
Oldsmaniac's Avatar
FYI, the 442 had a solid tube driveshaft and not 2 piece with rubber connector. The Cutlass had the 2 piece shaft. Will work fine but not recommended for racing. I have a couple from Cutlasses if interested. Both had Jetaway. NJ
Old Feb 28, 2011 | 05:06 AM
ROCKETMAN269V's Avatar
Smile '67 442 driveshaft
Just another FYI, the T-350 wasn't available until 1969 and then was not used behind big block engines.
Old Feb 28, 2011 | 05:32 PM
Flye's Avatar
Thanks for the additional info.
Putting a 2004r into a 67, and was told I needed the longer driveshaft in the shift from the TH400 to the 2004r..
Hadn't added the additional about the solid tube, etc.
Thanks,
Old Mar 1, 2011 | 05:01 AM
Smile '67 442 driveshaft w/200-4R
Are you using the stock 10-bolt rear? I will have to check my driveshaft stash, but I'm pretty sure that I have one to fit your combination. Thanks, Bob.
Old Mar 1, 2011 | 05:50 PM
Flye's Avatar
I have a 71 Olds 8.5 rear, and still using the stock 442 shaft as far as I know.
Thanks and let me know either through email or a PM on whether you have something.
NOTE: Also just saw that supposedly a 4 speed shaft would fit and be solid as well.
So anyone got one of THOSE laying around that they don't need?
Thanks,
Last edited by Flye; Mar 1, 2011 at 06:02 PM. Reason: adding note about 4 spd should work
jerseyjoe
Jul 12, 2019 10:08 PM
Mr Nick
Jul 5, 2013 03:24 PM
coppercutlass
Mar 1, 2013 07:33 AM
HouTXCutlass
Sep 9, 2009 06:56 PM
