Need SP T400 solenoid
Old Mar 14, 2020 | 12:15 PM
oldsbuff455's Avatar
I'm trying to locate a replacement solenoid for the switch pitch pump on a turbo 400 any suggestions?
Old Mar 14, 2020 | 12:53 PM
Instead of resurrecting an old unrelated post. I moved it to its own parts wanted thread. Good luck
Old Mar 14, 2020 | 12:55 PM
BeenThere's Avatar
Do you have a part number?
Old Mar 14, 2020 | 01:32 PM
Originally Posted by oldsbuff455
any suggestions?
Yeah, Type switch pitch solenoid valve into Google. Here's one of the first links that comes up.
https://www.ebay.com/itm/1965-1966-1...-/163456510155
Old Mar 14, 2020 | 01:39 PM
nicks1966's Avatar
I can't confirm the part number , but I found these listings
https://www.oldsobsolete.com/product...h-nos-1993690/
https://www.ebay.com/sch/i.html?_fro...93690&_sacat=0
Old Mar 14, 2020 | 01:43 PM
The part number for the stator control solenoid valve is 8623763
Old Mar 14, 2020 | 02:27 PM
BeenThere's Avatar
Nos
NOS in the original box. Oldsmobile part number 8623768. The top is stamped Delco-Remy with the Delco part number 1993690.
$149.00, includes safe insured U.S. shipping. Check or money order. PM me if interested.
Old Mar 14, 2020 | 02:31 PM
Originally Posted by BeenThere
NOS in the original box. Part number 8623768.
8623768 is the kickdown solenoid.
8623763 is the stator control solenoid. Wire for the stator solenoid is longer since it has to run from the backside of the front pump, through the case, all the way to the connector.
Old Mar 14, 2020 | 03:20 PM
So here is a picture of the actual original Kenne-Bell solenoid that mounts to the back of the front pump the center hole to hole measurement is 1.38 the ST-400 is 1.70" C to C so I guess that is not the correct number. Where could I find one of these beauty's?
Old Mar 14, 2020 | 03:23 PM
That is an aftermarket replacement item. The factory solenoid looks like the one in the link I posted. Did you install the old Kenne-Bell switch pitch conversion kit? Functionally, the solenoids are the same, as are the bolt patterns. Only the housing is different.
Old Mar 14, 2020 | 05:06 PM
Thanks Joe,
Yes this was the Kenne Bell kit for the turbo 400, this was the solenoid that came with the kit in 1981. So the factory one you mentioned will work just the same?
Old Mar 14, 2020 | 06:02 PM
Thanks Joe,
Yes. I installed one of those K-B kits back in the 1980s. Their pump bodies are all rebuilt OEM. That solenoid valve is just an aftermarket replacement. The OEM solenoid bolts up exactly the same.
Old Mar 15, 2020 | 06:25 AM
Any idea where I could find one? I did some searching on the internet and came up empty
Old Mar 15, 2020 | 06:28 AM
Did you not Post #4?
Old Mar 15, 2020 | 06:34 AM
That one is #1993690 the same as number 7 on this page I believe
Old Mar 15, 2020 | 06:43 AM
That is the stamped number on the cover, same on all of these solenoids. Again, the switch pitch solenoid is 8623763. The only difference between 8623763 for the switch pitch and 8623768 used for the kickdown is the length of the wire. The one in that ebay listing unfortunately has a cut wire if you look at it, but it does have one of the retainer clips used to route the wire on the valve body. In any case, the solenoid valve itself is the same, only the length of the wire is different.
Stop overthinking this. The solenoid valve is just an on/off valve. The bolt pattern is the same. Only the wire routing is different. I'm pretty sure no one makes new replacement solenoid valves for the switch pitch. You will either need to search for a good used one or lengthen the wire on one of the replacement kickdown valves to fit. If you search Google for TH400 solenoid valve, you get a lot that look like your old aftermarket one with a short wire.
Old Mar 15, 2020 | 07:42 AM
I do tend to overthink things Thank you for your help.
Old Mar 15, 2020 | 07:57 AM
rocketscientis's Avatar
I think I overthink also
Bout 10x faster than I can talk or text
Old Mar 17, 2020 | 09:37 PM
oldolds88's Avatar
I seen you talk,aint no one faster lol
Old Mar 18, 2020 | 10:46 AM
Now that you mention it.......
I should stop over what do you say about that???
Old Mar 19, 2020 | 08:00 AM
joe68h/o's Avatar
solenoid
I have a used one that is still mounted on the pump and checks good. $20 for solenoid and that includes priority mail shipping to US address
Old Dec 9, 2022 | 02:04 PM
Boomer1960's Avatar
Still available
I know this is an old thread but is the stator solenoid still available? Thanks in advance
ReallyWildStuff
Sep 13, 2017 01:14 PM
BeenThere
Oct 31, 2015 06:18 AM
89biff
Dec 2, 2014 09:22 AM
|-K|=K
Jan 11, 2011 06:45 PM
olds67
Sep 11, 2009 12:45 PM
