Need some 66 F85 stuff
Old Oct 17, 2015 | 01:50 PM
66 Olznut's Avatar
Ca's Only Official OLZNUT
I need a wiper switch and the pipe that comes out of the manifold and attaches to the choke coil on a 2 barrel carb. Also possibly a defroster duct, non ac car. I'm in 91351.
Old Oct 17, 2015 | 05:02 PM
Octania's Avatar
I knew I should have saved that 1966 2-bbl stuff!
Old Oct 17, 2015 | 06:56 PM
66 Olznut's Avatar
I could take the easy way out and swap a 4 barrel, almost did, but this thing is too nice and original. Sparky is gonna rebuild it for me.
Old Oct 23, 2015 | 12:12 AM
66 Olznut's Avatar
Another thing I need is on the right front passenger side window track where the regulator roller rides in, mine rusted away and fell apart. The window is supposed to sit in the channel.
Old Oct 23, 2015 | 01:43 PM
Olds442redberet's Avatar
I have a 67 F-85 and I might have what you need.
But I am no expert on these years.
I can send pictures upon request
Old Oct 23, 2015 | 04:57 PM
66 Olznut's Avatar
I know the wiper switch is different. Do you have a 2 barrel carb? Maybe you can get a pic of the right front door internals so I can see what you got? Has to be a 4 door.
lemoldsnut's Avatar
Is it a 2 door hardtop or post? I might the window track stuff. You can get a choke tube new from OPGI for a 70 4 barrel and it will work fine with just a very mild tweak.
Old Oct 23, 2015 | 05:09 PM
66 Olznut's Avatar
It's for my wagon. I was looking at the OPG catalog last night and was noticing how similar the choke tube looks to mine.
Old Oct 24, 2015 | 06:13 AM
I'll check the right front door internals this morning.
It's a four door
Old Oct 24, 2015 | 11:28 AM
lunaboy's Avatar
The Rocket Astronomer
choke
I saved this one and the carb from a 66 330 2 barrel
Old Oct 24, 2015 | 11:51 AM
66 Olznut's Avatar
I think I have a lead on a choke pipe, I'll keep you posted if it happens.
Old Oct 24, 2015 | 06:13 PM
according to the interchange manual 66 and 67 door glass is interchangeable
Old Oct 24, 2015 | 06:15 PM
Here's a picture of the donor car
Old Oct 24, 2015 | 08:03 PM
66 Olznut's Avatar
Just to verify that it's the right front door? Can you get it off the glass or will it be too much of a pain? If not, is the glass clear, not green tinted? And finally, how much shipped to 91351? Thanks!
Old Oct 25, 2015 | 07:00 PM
I have never been able to separate the two pieces.
It was an a/c car so let me check the glass again to see if it is tinted or clear.
Passenger door
I can't remember which one I pulled the glass from. But I have both sides.
Old Oct 25, 2015 | 08:18 PM
66 Olznut's Avatar
It appears to be clear glass in the pics, I just want to be sure.
Old Oct 26, 2015 | 02:01 PM
I checked it today
It's clear
I'll work up a quote and PM it to you shortly
Tom
Old Oct 26, 2015 | 02:39 PM
Shipping isn't cheap ($45.00). LOL
$70.00 shipped
Old Oct 26, 2015 | 06:15 PM
66 Olznut's Avatar
I didn't expect it to be. Do you take PayPal? If so, pm me your info. Olznut@aol.com Thanks again!
Old Nov 2, 2015 | 12:34 PM
66 Olznut's Avatar
Tom, did you receive the money I sent?
Old Nov 2, 2015 | 08:58 PM
Erin's Avatar
I have everything u need
I have a complete parts car, all good trim all window glass and tracks and molding good all badging and wiper switch there... parts won't be here long cleaning up yard, let me know what all u need make u a package deal.
Old Nov 4, 2015 | 12:03 AM
66 Olznut's Avatar
Tom, it came in today and looks great, thanks again!
Erin, is the wiper switch for 2 speed wipers? Are the 1/4 F85 emblems in decent shape?
Old Nov 4, 2015 | 06:38 AM
Run to Rund's Avatar
If you take a vacation in Vegas, you might look at the 66-7 stuff I have accumulated if you don't get all you need before then.
Old Nov 4, 2015 | 08:59 PM
66 Olznut's Avatar
I'm slowly getting what I need, My work schedule makes it a pain to actually work on the car, lol, just wanted everything on this car to work when I start doing trips. Thanks
Old Nov 23, 2015 | 12:22 PM
66 Olznut's Avatar
Thanks to all who has come through. I still need a few things.
Hot air choke pipe, manifold to choke, 66 330 2 barrel.
Wiper switch, 2 speed wipers, square motor.
Old Feb 6, 2016 | 12:40 AM
tcolt's Avatar
Did anybody ever find a source for the hot air tube for a 4-barrel intake manifold? The (factory correct?) 4-barrel manifold that I bought for my 1972 Vista Cruiser seems to have a different shape (1st picture) than the hot air tube that is in my 2 barrel manifold (2nd picture).
On the OPGI site I only found the version that I already had in my 2 barrel manifold. Were these hot air chokes so bad that they seem to mostly offer hot air to electric conversion kits?
Old Feb 6, 2016 | 06:18 AM
edzolz's Avatar
Your first picture is of a manifold that takes the coil spring type choke. The carb is the hot air tube type and is incompatible with that manifold choke type. One or the other will have to be changed to mate up properly.
Old Feb 6, 2016 | 06:28 AM
ROCKETMAN269V's Avatar
The "factory correct" intake that you show for your '72 350, is in fact for a '68-'69 350. These early intakes used a "divorced" choke, which had a coil mounted in the cavity shown in the picture and a rod that went up to the choke linkage. The later intakes have an actual "hole" in the crossover passage that is covered by a plate, with a bent tube that goes into the passage to pick up heat for the "choke stat", that is inside the black bakelite cover on the side. The heat is drawn in by a vacuum port in the carburetor.
Old Feb 6, 2016 | 10:44 AM
tcolt's Avatar
Thanks guys. :-( It was sold to me as a 1972 manifold and the casting numbers matched those for a 1972 manifold on Rocketscience's thread about manifolds. https://classicoldsmobile.com/forums...-thread-3.html
It looks like the casting number alone isn't what determines the identity of the manifold?...
marxjunk
Sep 24, 2014 03:20 AM
OldsMotion
Oct 9, 2009 09:43 PM
Cameo White
Jul 31, 2009 07:07 PM
gearheads78
May 28, 2008 08:38 AM
53Ford
Feb 24, 2008 04:10 AM
