Muncie M21
i know it is not an M-21 but i have an M-20 that was removed from a 72 cutlass with linkage and factory hurst shifter. it has a lever for a non console car. i am missing one rod for the reverse lock out. i have not opened the side cover up to look inside yet. i even have 4 speed cranks, flywheels, bellhousings, pedals... i am in Brazil IN so maybe not to far to drive?
Just a thought.
It's not that simple.The input shaft of the manual transmission needs a hole deeper than the depth of the existing automatic hole,so you need to make a relief hole for the end of the input shaft to pass into.The adapter bushing also needs to be inset from the edge of crank.If it is flush with the end of the crank,it will not work,or be in a bind.The splined part of the input shaft actually starts to enter the crank.I think this is also why you see some manual transmission with the ears broke off.People think they can just keep tighetening the bolts to get the transmission to seat into the bellhousing.Nope.There is a reason why it is not going in,so don't force it.A home-made adpater bushing can be made,for those of you that have an engine that is assembled.It's only going to be about 3/8" long/deep,and you will need to drill a relief hole for a void,for the tip of the input shaft,but it will work.
Machining the crank would be the best option though.
fast67vellen2o
September 27th, 2010 01:18 PM
