Looking for Steel Flywheel for a 455
Old Jun 23, 2012 | 04:48 AM
vin442's Avatar
Looking for Steel Flywheel for a street 98% - /strip 2% 455 with a manual transmission which will be installed in a 68 Cutlass Post. The motor is currently at the machinist and I would like to get this to him for balancing in about 2 weeks. Please reply with price and shipping to 07066. Thank you, Vin
Old Jun 23, 2012 | 07:31 AM
Run to Rund's Avatar
You can find the PRW steel wheels on ebay, SFI certified. Even if a track let me, I would never run with a cast wheel. Get an SFI appproved clutch also. I like the Quick Time bellhousing--very strong, lighter than Lakewood by about 12-15 lb.
No matter what housing you select, you must align it to the block. Lakewood makes offset dowels.
Old Jun 23, 2012 | 08:19 PM
jensenracing77's Avatar
what are the factory ones? i have 6 original ones and an aftermarket one. i thought they were all steel? if one of these are what you need send me your email address and i will send you pictures.
Old Jun 23, 2012 | 08:30 PM
W70442's Avatar
I had the replace the rear main seal in my 70 442 4 speed last fall and went ahead and replaced the clutch, pressure plate and flywheel so I have the factory flywheel just laying around. It was a little glazed from the seal leaking oil on it but you'd want to turn it anyway. Shipping looks like it would be $26. I'd sell the flywheel for $25 + ship to get it out of my way.
I actually have the stock clutch and pressure plate too if you (or anyone for that matter) can use them. Not sure if the clutch disc can be re-used or reconditioned etc after getting oil on it but, if so, it's available. Pressure plate should be fine. I think I only put about 5000 miles on them if that.
Randy
Old Jun 23, 2012 | 08:33 PM
All factory wheels are cast. You can see the as-cast finish on the side facing the engine block.
Old Jun 25, 2012 | 01:45 PM
is there a way for me to determine if my aftermarket one is steel? i found numbers on it but can't figure out who made it. the numbers are 40-25568 if that tells anyone anything.
Old Jun 25, 2012 | 04:53 PM
Post photos of both sides.
Old Jun 25, 2012 | 05:06 PM
these are pictures i had on the computer already. i hope they are clear enough.
100_4989-2.jpg?t=1340669099
100_5031-2.jpg?t=1340669138
Old Jun 25, 2012 | 06:24 PM
That appears to be an older design steel wheel. If it has a machined surface everywhere, it is probably steel, not cast.
Old Jun 25, 2012 | 07:05 PM
vin442... if this will work for you i have $90 on it. it is machined everywhere but i don't know any more than that.
thanks, Run
Old Jun 26, 2012 | 07:41 PM
ihengineer76's Avatar
jensen, if vin442 doesn't want it, I would take it. I'm converting my car to a 4 speed and need a flywheel also, but the OP gets rights to first refusal.
Thanks.
Tom
Old Jun 27, 2012 | 02:09 AM
Thanks.
Tom
if you are ok with a stock one i have 5 of those. also $90 plus shipping. i would consider all of them as needing surfaced. send me a PM if a stock one will work for you.
Old Jul 16, 2012 | 08:34 PM
vin442's Avatar
Thanks to all who posted. I went ahead and ordered the PRW flywheel as the machist needed it pretty quick. Jensen, Go ahead and offer it up to Tom. Thanks again for everyone's input. Hope to be running in the Fall! Take care, Vin
Old Jul 17, 2012 | 11:45 PM
64Rocket's Avatar
Almost all the 455 Olds powered jet boats have the stick flywheel. That is where I pick up most of mine. They also have stick crank shaft.
Gene
Old Aug 23, 2012 | 06:15 PM
Railguy's Avatar
No matter what housing you select, you must align it to the block. Lakewood makes offset dowels.[/QUOTE]
This is probably dumb question but.How do you align it to the block?Also when changing from auto to manual do I need to change the harmonic balancer?
railguy
Old Aug 24, 2012 | 11:06 AM
64Rocket's Avatar
No need to change the balancer.
If you have all the factory parts to do your change over, you should be good to go. It has work fine all these years. If you are using after market parts, then may be a good idea to align like they say.
Gene
Old Aug 24, 2012 | 05:03 PM
Attach a dial indicator to a stud going into a flywheel mounting hole in the crank. turn the crank and indicate the hole for the transmission to see if it is perfectly in line with the crank. Also indicate the trans mounting surface to see if it is parallel with the rear face of the block by moving the indicator needle from the hole to that surface.
Old Aug 26, 2012 | 09:40 AM
Railguy's Avatar
Is this a good Flywheel?
http://www.ebay.com/itm/221093915916...r#ht_634wt_906
The cheapest one from summit is $350 seams to good to be true.
Bernhard
Nov 24, 2022 09:12 AM
ahfoxman
Apr 29, 2014 09:58 AM
starr88
Apr 23, 2013 09:44 PM
sx455raidercelticfan
Nov 23, 2010 05:45 AM
oldzy
Jan 29, 2010 06:06 PM
