looking for m20 or m22 tranny
Old Jun 1, 2009 | 02:11 PM
olds4life's Avatar
hey olds nations!!!! i need a 4 speed tranny to hook up to my 455. i am located in st. louis mo. wghaskins@yahoo.com
Old Jun 1, 2009 | 04:53 PM
jensenracing77's Avatar
i see them on e bay all the time but get your wallet ready. i have an extra M21 that needs rebuilt but scared if i get rid of it i will break mine.
Old Jun 1, 2009 | 05:12 PM
Nilsson's Avatar
I came across this establishment while at a swap meet here in central Ohio a couple weeks ago. I have them on my list of possibilities to freshen up my Muncie this winter. They repair and sell rebuilt units and they seemed straight up. If anybody on this board has had any experience with them please share.
HP Trans
Knoxville TN
ph Shop
865-573-6395
ph Gary
865-254-8639
ph Robert
865-254-8739
website is muncietrans.com
All this info is off the business card I was given
Let me know if you contact them and what you think.
Old Jun 7, 2009 | 09:27 AM
Warhead's Avatar
I have one from a 64 Chevy, rebuilt.
You will have to figure out how you want me to send it.
http://phoenix.craigslist.org/nph/pts/1209662999.html
I will send out of town for a board member.
I will go $500, shipping not included.
An aquaintance may be going back east for possible delivery solution.
If paypal, add 3% for all monies being sent.
Jim
Old Jun 7, 2009 | 10:54 AM
442garage's Avatar
This AUTO GEAR MUNCIE M-22 has less than 100 miles on it. We changed it out to a Richmond 6-Speed because we needed a very low 1st gear plus overdrive. Trans is perfect just driven to a few car shows. 2.19 first---1.64 second---1.27 third and 4th is direct. These trannys are a copy of the Muncies only with every part being stronger. Gears are made in Italy by Masiero. No China parts. All bolts are grade 8 and it takes a turbo-400 yoke on the output shaft. You can look up the specs at autogear.net. It takes a standard Hurst competion plus shifter or any other similar shifter. 26 spline input shaft. $1500.00 firm, shipping to lower 48 only.
Old Jun 8, 2009 | 02:39 AM
Bobsw32's Avatar
BobsW32
Just a thought.....The Borg Warner Super T-10 bolts right up.
Usually you can find a used one for less than a Muncie.
They are stronger than the muncie.
They have many many different gear ratios which are an advantage on the street. All the way down to a 3.44 first gear model.....there are 2.88 first gears and 2.64 first gear models... These will let you run a higher rear end ratio and still take off zoom zoom at the light.....
JUST A THOUGHT
Old Jun 8, 2009 | 09:02 AM
olds4life's Avatar
hey olds nation! thanks for the responses.
Old Jun 8, 2009 | 03:55 PM
Warhead's Avatar
JUST A THOUGHT
Yes they are stronger.
Without a doubt.
May, or may not be cheaper. Check prices locally, and on e-bay.
Will need larger output shaft, fine spline clutch.
Muncies have many different gear ratio's also, just remember that a higher numeric 1st gear will reduce torque rating on any trans.
Jim
Old Jun 10, 2009 | 08:35 PM
hamm36's Avatar
http://stlouis.craigslist.org/pts/1207595039.html
Old Jun 10, 2009 | 10:58 PM
Run to Rund's Avatar
What are you doing with the car? Racing, slicks, etc? You can get a new ST10 from Jegs or Summit for around 1600 shipped, or spend about double that for a Jerico with the ratios you want, and the strength.
Old Jun 11, 2009 | 06:28 AM
olds4life's Avatar
racing, nahhh! i am a cruiser. i might spend the tires once or twice a year but other that its cruise mode. it originally came as a manual so i would loooove to go back to it. a 442 with big block stick would be great.
Old Jun 11, 2009 | 08:30 AM
wmachine's Avatar
Trying to remember member
Just to clarify, I think you mean an M21 (close ratio) or an M20 (wide ratio), not an M22. The M22 (aka Rock Crusher) is a heavy duty close ratio that will usually be much more expensive to get.
Old Jun 11, 2009 | 04:23 PM
Warhead's Avatar
You swine!
Old Jun 11, 2009 | 04:59 PM
Nilsson's Avatar
A big block with stick gets my gets my heart racing every time I get behind the wheel. To me it is the ultimate Oldsmobile experience.
Old Jun 11, 2009 | 05:33 PM
wmachine's Avatar
That's exactly why I have 4 that are like that!!!!
costpenn
Jan 20, 2012 02:44 PM
Seff
Mar 10, 2011 03:05 PM
fast67vellen2o
Oct 4, 2010 11:02 AM
Aceshigh
Jan 18, 2010 11:06 AM
woodie582
Jul 25, 2008 06:48 PM
