Looking for a 1967 Cutlass Supreme Type "O" rear axel housing
Old Jun 15, 2021 | 06:01 PM
Dune67's Avatar
I've got my '67 Cutlass Supreme in the shop and the mechanic told me my rear axel housing is "fubar" and therefore the axel bearings can't seat in it properly. He says I need to find a new axel housing for the guts of my rear end (I had a posi put in it a few years ago that I'd like to keep, plus I want to keep the correct type of rear end to the car).
Does anyone have any leads on where I might find a housing for a 1967 Olds Type "O" 12-bolt axel? Or have any advice one what I should do?
Old Jun 15, 2021 | 06:31 PM
tiogatwister's Avatar
I have a 68 type O, not sure if there is any difference? Where are you located, that may be the more important question..? PM me if you have interest.
Old Jun 15, 2021 | 07:10 PM
OLDSter Ralph's Avatar
I left you info for someone that might have one in Redmond Or. Lemoldsnut on here. (541) 815-4363
Old Jun 16, 2021 | 01:19 AM
442mark's Avatar
I have an O-type 2.78 rear from a 68 Cutlass, complete except brakes. Also have an O-type bare housing from a 69 442. Both are not currently in cars. They should be the same as 67. The bonus is I live not far from you, so no shipping. Poulsbo 98370.
Old Jun 16, 2021 | 05:54 AM
The parts book says that the 1967 and 1968 housings have exactly the same part number.
Old Jun 16, 2021 | 06:58 AM
7314haywood's Avatar
If indeed 68 is the same I'm pulling mine complete out sometime this winter and installing a Quick 9 inch. Mine is 2.78 non posi with 96k. Not abused or beat on. I'm in Az and might be pricey shipping but would sell at a fair price.
Old Jun 16, 2021 | 07:14 AM
67-68 non-performance axle housing is P/N 230727. This is also the same P/N for all 1969 applications.
67-68 performance axle housing is P/N 230575.
The performance housing is for ratios 3.42 and numerically higher. I'm frankly not sure what the difference is, as the bearings (wheel, pinion, and carrier) are the all the same for both. The only difference is the axle shafts and the carrier, which shouldn't matter for the housing.
Old Jun 16, 2021 | 08:05 AM
MI68442W30's Avatar
the performance housing [31 spline axles] has a different part number because the carrier bearings are different and larger than the non performance housing
Old Jun 16, 2021 | 08:38 AM
EDIT: Corrected info. See post below. Sorry for the confusion.
Old Jun 16, 2021 | 07:26 PM
2blu442's Avatar
I'm down in Medford Oregon and have some extra rear ends. Would probably still need shipped but if you wanted a bare housing that would make it lighter. Let me know if you'd like to see pictures and a price.
I just took the time to read through all the posts. 442mark should be the first person you check with. If you can drive to pick it up that will save you money and trouble!
John
Old Jun 16, 2021 | 07:31 PM
I wonder if volume inside the case was greater for the performance one.
Old Jun 16, 2021 | 07:38 PM
65B01Delta's Avatar
I have a complete rear end out of a 67 Cutlass California car 12 bolt located in the great state of Indiana. Shipping cost would be an issue. PM me if interested.
Old Jun 16, 2021 | 10:16 PM
That's what I would have expected, but the parts book shows P/N 7451155 bearing for all 8.5" Type O axles. I know the HD axles used the same side gears as the 9.3" Type O. Does that mean that the carrier bearings are the ones for the big car axle also? That would be P/N 7451409, which is not what the parts book says (thought it wouldn't be the first time an oddball application was not listed).
Joe, I recorded the bearing numbers that were in my 31 spline O-Type and 28 spline O-Type but I don't have a cross reference to the GM part numbers.
31 spline carrier bearing = LM603012 (3.061" OD race/LM603049)
28 spline carrier bearing = LM501314 (2.890" OD race / LM501349)
Old Jun 17, 2021 | 06:03 AM
Good info, thanks.
I have to apologize. I pulled the wrong page from the parts book. The correct page does show different bearings for the 67-68 31 spline axles. Mystery solved. Sorry for the bad info.
The 31 spline carrier bearing is P/N 7451140, which crosses to LM603012. This is the same P/N for a Chevy 12 bolt and the 9.3" Type O from the full size cars.
The 28 spline carrier bearing is P/N 7451281, which crosses to LM501314.
Old Jun 19, 2021 | 11:23 AM
Dune67's Avatar
Thank you all for the responses. I was able to get exactly what I needed from Lemoldsnut without having to ship.
Dune67
Drivetrain/Differentials
33
Aug 16, 2021 07:40 PM
otto72
Sep 25, 2020 03:55 PM
mineseats9
Jan 19, 2018 04:29 PM
coppercutlass
Oct 16, 2013 05:38 PM
idaholc
Jun 1, 2009 09:22 PM
