ISO Kick Panel Clip for 1968 Cutlass
Old Jun 4, 2019 | 01:01 PM
Tjohn8573's Avatar
I’m looking for a kick panel clip like the one pictured for a 1968 Cutlass. Thanks!
Old Jun 11, 2019 | 08:34 PM
Tjohn8573's Avatar
Ttt
Old Nov 17, 2019 | 08:25 AM
Tjohn8573's Avatar
Originally Posted by Tjohn8573
Ttt
ttt
Old Nov 17, 2019 | 10:26 AM
Tjohn8573's Avatar
Figure 1 of this drawing is the clip I looking for. I’m also in need of the 5 screws in the picture that hold the kick panel in place. Thanks!
Old Nov 17, 2019 | 12:01 PM
70Post's Avatar
I'll check at a place this week....they have a couple '68's. Seems like they should have the clips BUT....do you know if AC-equipped '68 Cutlass's used the same clips on the kickpanels?? (Probably no non-ac cars down here).
As far as the screws - those can be a real PITA to pull. The factory really ran them in tight into the plastic panel behind the vent louvers. I've removed them before but they put them in so tight it's sometimes almost impossible to get a socket onto the screw head. Again, probably no non-ac cars at the place here but let me know on the clips.....check your Assembly Manual and see if the clips were used on the AC kickpanels as well.
The screw will be a #8 thread size - sheet metal threads. You can source locally if you can figure out, generally what length they need to be. I believe they are "hex flange" heads on those screws.
Old Nov 17, 2019 | 12:29 PM
Tjohn8573's Avatar
Thank you! I checked and the a/c kick panels do use the cli as well.
Tjohn8573
Feb 15, 2019 11:32 AM
6884rocket
Nov 1, 2016 11:34 AM
keepitolds
Apr 16, 2014 04:03 PM
rlang
Nov 3, 2008 09:05 PM
2oldsguy
Dec 23, 2007 03:50 PM
