ISO 65-68 3 Speed Reverse Light Switch Mounting Bracket
Old Jan 9, 2024 | 08:04 PM
66-3X2 442's Avatar
Looking a a 65-68 3 speed Dearborn Phord reverse light switch mounting bracket.
Old Jan 26, 2024 | 11:34 AM
Oldsmaniac's Avatar
Not selling but I can give you some pictures, seems not too hard to make unless originality is an issue. I had been searching for a long while checking Ebay etc, found nothing and it seems its an Olds only item, other GM cars used a different setup. Happy that the one I have was included with the 67 442 just purchased, 3 speed.
Old Jan 26, 2024 | 03:11 PM
Rallye469's Avatar
Mike, any chance it was also a Ford item?
Old Jan 26, 2024 | 04:29 PM
2blu442's Avatar
Can you post some pictures here? Someone may have this laying around and not know what it is. John
Old Jan 26, 2024 | 06:06 PM
66-3X2 442's Avatar
Thanks and I have pictures of it. Hard item to find for sure.
Old Jan 26, 2024 | 06:07 PM
66-3X2 442's Avatar
Don't know but I doubt it. Like oldsmaniac said it's different between GM brands,
Old Jan 27, 2024 | 04:05 AM
Oldsmaniac's Avatar
I will post some picts that came with my 67 3 speed.. from memory does not seem to be what is pictured here.
Old Jan 27, 2024 | 04:52 PM
Oldsmaniac's Avatar
Old Jan 27, 2024 | 04:58 PM
66-3X2 442's Avatar
The one I posted pictures of looks just like the picture diagram in the 66 PIM. Maybe there was a change in 67,don't know. If you look @ my pictures you see there's a u shaped opening for the switch to go into. Yours has a round hole for the switch to go through. Somebody posted a picture of a Pontiac bracket that looked kinda like yours. I'm going to look in my 67 PIM to see what it shows.
WOW,now I'm losing my mind. The 66 & 67 PIM picture diagram shows them being the same and just like yours. I know I saw a picture of a bracket just like the one I posted but can't remember where.
Old Jan 27, 2024 | 05:24 PM
Oldsmaniac's Avatar
I believe the 67 manual shows something similar to mine with the tab and 1 bolt mount. I have seen a Firebird one that uses a bolt hole on shifter body to mount a bracket for a push button switch, my shifter has no hole for this one.
Old Jan 27, 2024 | 05:52 PM
66-3X2 442's Avatar
You are correct. My 66 & 67 PIM show the same bracket being used both years. The bracket I have came from a 68 guy and he said it came from a 68. It could be that it was changed in 68 so it would have 2 bolts holding it instead of one. We are going to put it beside a transmission to see if the bolt holes line up with bolts on the transmission & that will give us the answer. Is yours for sale? if not would you be willing to let us borrow or rent or?. I think we can make one if we had a sample. We could also copy the rod as we don't have one.
Thanks for your help.
Old Jan 28, 2024 | 05:32 AM
Oldsmaniac's Avatar
As hard as these are to come by, I wouldn't let it out of my sight but can trace it out on cardboard if you wanted and send to you. When I put a Dearborn in my 67 wagon I have been on the hunt for years with nothing found and as luck would have it my recently purchased 67 442 had the original assembly in the trunk with some other parts.
Old Jan 28, 2024 | 07:32 AM
66-3X2 442's Avatar
I completely understand and that was a great find. I would greatly appreciate a tracing if you're willing to do that and will certainly compensate you for your efforts.. I never thought this bracket would be so hard to find.
Thanks, Mike
Old Jan 29, 2024 | 05:48 AM
Oldsmaniac's Avatar
Send me a PM with your address.
Old Jan 29, 2024 | 08:23 AM
66-3X2 442's Avatar
PM sent and thank you very much for your efforts.
Mike
Old Jan 29, 2024 | 02:35 PM
66-3X2 442's Avatar
Would it be possible to get a thickness of the bracket using a micrometer? Thanks Again
Old Jan 29, 2024 | 06:23 PM
Oldsmaniac's Avatar
Just so happens the cardboard used is the same thickness of the bracket, should mail tomorrow.
Old Jan 29, 2024 | 07:03 PM
66-3X2 442's Avatar
That's great and thanks again.
Old Feb 14, 2024 | 03:37 PM
Oldsmaniac's Avatar
Tracing of rod.
Old Feb 14, 2024 | 04:08 PM
66-3X2 442's Avatar
Tracing of rod.
OK,looks great. Thanks
Old Mar 17, 2024 | 10:31 AM
DoctorL's Avatar
Were you able to machine a copy? I am in need of the same bracket and item with no luck.
Old Mar 17, 2024 | 10:39 AM
66-3X2 442's Avatar
Yes, my friend who needed it had one made and it was perfect. I thought about having some made but I don't think the demand would drive the cost.
Old Mar 17, 2024 | 10:50 AM
DoctorL's Avatar
Are you able to make an additional? Or put me in contact to have one made for myself?
Old Mar 17, 2024 | 11:04 AM
66-3X2 442's Avatar
He actually made 2 but said he wasn't going to make anymore. It was very labor intensive and he paid good money for them. He paid $300 each for them.
Old Mar 17, 2024 | 03:57 PM
DoctorL's Avatar
I can imagine. Thank you for getting back to me. If he ends up wanting to sell that second one, I'm interested!
Old Mar 17, 2024 | 04:55 PM
66-3X2 442's Avatar
We borrowed one from a friend who needed another one, so my friend is using one and the friend needing another is getting the second one. I know how you feel needing one and can't find it. I do have a pattern made by a fellow member here of his original. You're welcome to use it if you want to try and make one.
Old Jul 6, 2024 | 06:41 AM
DoctorL's Avatar
If you are able to share the pattern, I am all for it!
Mar 23, 2023 12:39 PM
Oldsmaniac
Mar 17, 2019 06:21 PM
yellowone
Oct 29, 2018 03:08 PM
olds70supreme
Aug 28, 2018 05:32 PM
Mickey2112
Mar 5, 2018 09:34 AM
