Inner Fender to Frame Bumper
Looking for a source for the rubber bumper that goes between the rear part of the inner fender and the frame on a 66 Cutlass. Approx 1" in diameter, snaps in to the fender.
I’ve had success with Steele, Rubber The Right Way, Metro, Fusick, and Soffseal for my ‘66 big olds. You might also check Clips and Fasteners.com
I think my 98 uses similar or the same bumper on the underside of the trunk deck lid. I think my Starfire, therefore the 88’s of that year do too.
Good luck on the hunt. I’m pretty sure this is out there, mine don’t look original.
Chris
Chris
Trunk Lid Bumper
17-005B
$3.28
ea.
Fitment Data
Rubber the right way, but it looks a bit different. Sorry if I misdirected you.
cf
I'm not sure if correct size is among the bunch, but I found a number of similar bumper/buttons here, at Restoration Specialties.
You may find them here as well, at Minor Rubber.
Last edited by BackInTheGame; June 19th, 2020 at 09:56 AM. Reason: additional info
Ok
bout 7/16 dia rubber /plastic body plug
Sold some to California man while back as climate is murder on them...his were fore holes atop firewall ..under cowl
..where are yours located ??
How many required?
How many required?
My 67 also has 2 on each fender. After lots of searching on the Internet, I got 2 different variety boxes of general purpose bumpers, and nothing in either one worked. I put a bumper in a grommet and got something "functionally equivalent" so I could put the car together with something besides the old rotten stuff. It was a tight fit. I put both in warm water for a few minutes, put the grommet in the inner fender hole, then pulled the bumper through with pliers. I broke a few of the bumpers in this effort.
The bumper kit is #8210 from Clips and Fasteners and the Grommet Kit is from Harbor Freight.
