I need a set of 350 head bolts
Old Aug 18, 2011 | 02:42 PM
76Supreme350's Avatar
Need a set of head bolts. Dont really want to pay for the 80 dollar arp ones. Anyone have a set or know where i can get some?
Old Aug 18, 2011 | 04:07 PM
Dave Siltman's Avatar
The ARPs might sound expensive now but....... in the big picture you might be doing yourself a favor using them. I sure WOULD NOT recommend using used ones if you are doing a fresh re-build. I'll repeat my motto again---"Do it nice, not twice!" There are new replacements available but probably won't be a whole lot cheaper.
Old Aug 18, 2011 | 04:14 PM
therobski's Avatar
X2, I understand the budget thing, slow the build down a bit if you have too and buy ARP's. I do have a new set; unopened ARP rod bolts for a 425, maybe the same, if interested I can cross match the part numbers, I'm thinking $50.00-Merry Christmas...
Old Aug 18, 2011 | 05:56 PM
I disagree.
The standard-type head bolts are non-stretch and can be reused without a problem.
Obviously, if you're building an engine to have much higher CC pressures than stock, you might want to consider stronger bolts, but if it's just a regular rebuild, there's nothing wrong with reusing head bolts.
Old Aug 19, 2011 | 05:18 AM
507OLDS's Avatar
If you need the factory style head bolts,I have plenty of them.I've used factory bolts,ARP bolts,and ARP studs,depending on the application.
Old Aug 19, 2011 | 06:16 AM
Tony72Cutlass'S''s Avatar
I totally reused most engine bolts when i rebuilt my 6 Cylinder marine engine, probably not the same as an awesome Rocket V-8.
But, the engine has been running strong for 4 years now. I can't kill it!
Cheers,
Tony
Old Aug 24, 2011 | 12:53 PM
Well, thank you for the replys but this build is taking long enough as is. Its just a very mild build, just all top end stuff. I actually got rid of the car the motor came out of the other day and when I was cleaning it out I found the stock head bolts sitting inside the valve covers. I'm going to go ahead and use those and finally start putting this motor together!
Old Aug 24, 2011 | 01:09 PM
They're always in the last place you look .
stanzaschance
Jul 28, 2015 06:38 AM
nolabigdawg
Oct 25, 2014 11:50 AM
Olds Scott
May 29, 2013 08:15 PM
Oldssupreme
Feb 6, 2013 12:39 AM
Kidcutty
Jun 9, 2011 03:00 AM
