Vin Decoder
or
Login with Facebook
A head rocker arm washers needed
September 4th, 2011 | 09:58 AM
TK-65
Feb 2009
I need 16 of the rocker arm nut washers. Small, very thin, hardened washers that go under the rocker arm nut. Used on 65 A heads and 65 330 heads.
TK-65
Find More Posts by TK-65
September 4th, 2011 | 10:00 AM
defiant1
Jan 2010
What kind of valve train/components did you install?
d1
defiant1
Find More Posts by defiant1
September 4th, 2011 | 10:11 AM
Run to Rund
Mar 2008
Try
www.mcmaster.com
Run to Rund
Find More Posts by Run to Rund
Control Arm Bolts - Washers?
kstern58
December 7th, 2014
02:18 PM
rocker arm head question
The Flash
July 9th, 2014
07:02 PM
Control arm shaft washers?
805cut
Suspension & Handling
September 12th, 2012
01:54 PM
Control Arm Washers/Retainers
Jetstar 88
January 30th, 2012
05:14 PM
Thin Washers For Shifter Linkage
nelsontj
May 5th, 2010
05:30 AM
63 cutlass F-85 power steering gear-pulleys
Posting Quick Reply - Please Wait
Quick Reply:
The following errors occurred with your submission
Okay
Quote message in reply?
02:13 PM
