Fuel Pump Eccentric
Old Mar 8, 2013 | 09:48 AM
Olds442redberet's Avatar
Fuel Pump Eccentric
I need a fuel pump eccentric and the bolt the holds it on. Mine backed out causing severe damage to both parts.
Old Mar 9, 2013 | 04:33 AM
ROCKETMAN269V's Avatar
Smile Fuel Pump Eccentric
I have several of each. Where are you located? Thanks, Bob.
Old Mar 9, 2013 | 06:18 AM
Octania's Avatar
Gotta wonder how that happened- not torqued right?
I have never seen that, in oh I guess 100+ engine dismantlings.
I too have plenty of them so looking at the cost of postage.
Old Mar 9, 2013 | 06:44 AM
I've got to believe that he it also tore up the front cover; that's what the factory bolt rubs against. Ahah!! Maybe someone used a regular bolt to secure the eccentric
Old Mar 9, 2013 | 08:20 AM
Octania's Avatar
Hmmmm.... the only timing cover I have ever seen with witness marks of cam contact was one that died on impact with a pole, which crammed the water pump into the cam.
To clarify: the cam bolt has a protrusion to prevent the cam from walking fwd in case that ever has occasion to happen.... but with the distributor/ oil pump drive gear constantly tugging the cam aftwards.... that just never really happens. In my experience.
Old Mar 10, 2013 | 04:04 PM
All I know is, I took the water pump off of the car and the timing chain cover pushed outward destroying the blades on the water pump. I took the timing chain cover off the engine to see what was happening underneath and discovered the eccentric bolt was spun out and stripped. I mean the threading on the bottom 3/8 inch of the bolt was wiped clean. And the eccentric pin / tab was broken off. so it spun freely.
The car runs great! And it doesn't look like it has had a rebuild yet.
I never seen this before either.
Old Mar 10, 2013 | 04:29 PM
Wow. That's weird.
I'd love to see some pictures.
Old Mar 10, 2013 | 05:36 PM
I'll post a picture of the eccentric and bolt after I get them back from the shop.
I received help from a fellow member in locating a replacement eccentric and bolt. Thanks!
The timing chain cover was repaired with a large hammer.
Old Mar 11, 2013 | 08:24 AM
OldsMotion's Avatar
OldsMotion
Ive seen one other where the incorrect sized back cam plug was tapped in too far. and yes, the dist/cam gear was shot as well... probably why the motor didn't live long and was pulled, most likely replaced with a chebby lump.
Bonus for me was a very nice new set of pistons, rings and bored and honed block.
John
512Lac
Apr 5, 2014 04:10 PM
Derrick
Aug 31, 2011 11:25 AM
rhett838
Aug 24, 2010 07:15 PM
80_cutlass
Aug 30, 2009 01:46 PM
jr711
May 27, 2009 04:06 PM
