exhaust manifold passenger side 72 Toronado
I need the passenger side manifold for a 72 Toronado........the one I have is cracked
Larvets
403 in 78 chevy 4X4 truck only mahifold that will fit in the tight space
Larvets
A manifold from any Olds small block should bolt up if you need one to get you by until you find the correct 72 Toro one.
Post a letter code for it and the number. I'm sure someone has one.
Till then, grab one from a 307, or 350.
I believe J is correct. It is the driver's side manifold that is different on a Toronado. However, you should just have the one you already own repaired. I have had a good welding shop weld a cast iron manifold before, if they know what they are doing you won't have any problems.
One of them won't work, but not sure which.
The late 70s toros used the 307 manis though I believe.
Doesn't matter much though, if you get the wrong one, at least they're dirt cheap.
I've got some Toro manifolds, I know I have a set from 1970 and several sets from the mid-late 1960's. Would you post the casting number and the large letter that's either near the #2 or the #8 spark plug location? John
620 395752 RH Toronado '67-'71
Try calling these guys.
262-692-2447
If they don't have an exact, you can always try sticking a 307motor one on.
2BLU442 I'm sure has one that will suffice.
I'll check my garage as well.
262-692-2447
Thanks for the info, what should a manifold cost? I am really kinda new with this stuff.
What would it cost to ship on to Kansas City, Mo.?
Once again I really appreciate the quick and helpful responses.
Larvets
Larvets
Larvets, if you are in K.C. just pm me with contact info and I will take you to a salvage yard and we will find you a manifold for less than $30. Or, better yet, we could take that cracked one you have to the specialty welding shop I use for just such occasions and we could ask Claude to fix you up for about the same price. I live in Lees Summit.
ratified442
December 8th, 2013 06:18 PM
crazy'boutOlds
August 11th, 2009 07:16 AM
