Engine anyone????
Old Sep 25, 2012 | 03:58 PM
My1st olds69"S"'s Avatar
Engine anyone????
Hello, I am looking for an engine for my 69 S, or any other parts that are in good shape. I am doing a complete restoration on the car. Looking for a 350..
Old Sep 25, 2012 | 04:01 PM
ah64pilot's Avatar
This needs to be moved to parts wanted...
Are you looking for a particular year 350 or just any will do?
Old Sep 25, 2012 | 04:12 PM
Yeah I realized that as soon as i posted it..still green to this. I would love to have one closer to that year earlier or later, but almost any would do. Right now I just want to get it back on the road.
Old Sep 25, 2012 | 04:14 PM
Engine anyone????
Old Sep 25, 2012 | 04:15 PM
L69's Avatar
L69
Im in CT and I have several 350's I dont believe I have any 69's but several 68's
Old Sep 25, 2012 | 04:47 PM
oldspackrat's Avatar
I have a shell of a '69 Supreme with the original engine still in it. It is missing the intake/carb, but otherwise complete I think.
It was running when it crashed & then went to a junk yard. I would sell it as an engine needing rebuilt as I don't know how long it sat in the yard.
I'm in Indianapolis & might be able to meet you half way if interested?
Thanks.
Scott
c. 317-727-7041
Old Sep 25, 2012 | 08:42 PM
OldsMotion's Avatar
OldsMotion
Well, the block is the same from 1969 all the way up to 1975 (or maybe 6) I can never remember. #6 heads are the year correct heads for that car, but 5-8 heads can be worked for power.
I'm in SC and have several 350 cores that require various degrees of work, but it sounds like you want a runner?
John
Old Sep 25, 2012 | 08:53 PM
Fakser's Avatar
Do you have a budget? Are you looking for a turn key engine to drop in and hook up, performance parts, what type of gauges will you use, a lot of questions come up to help you find something that will best fit your need. I'm sure someone here has something for you for the right price.
Good luck
Old Sep 25, 2012 | 10:08 PM
Mr Shifty Sidney's Avatar
I have a 350 out of a 72 that I would like to sell. It ran when pulled, but I would really only consider it a good engine to rebuild. The car was driven 45 miles to my house and the engine was pulled. I am in southern KY just off I-65. If you are interested PM me. $250
Don W
Old Sep 25, 2012 | 10:22 PM
RunTuWin's Avatar
I have a 350 Rocket out of a 69' that I just pulled. It still ran when I pulled it but had a rear main seal leak. I'm in California and the engine is near Fresno if interested. Looking to get rid of it for $750
Everything is there.
Here is a picture.
It also has a high performance Edelbrock Carb and Intake. I have the original intake and carb as well that I would ship.
Old Sep 26, 2012 | 05:10 AM
507OLDS's Avatar
Complete 1972 350 with TH350 transmission still attached.It was running & driving when pulled last year.Carb was removed,but everything else is still on there.
Old Sep 26, 2012 | 05:32 AM
Chesrown 67 OAI's Avatar
68-70 350 use the same casting number block - so any of those would work as a "correct" motor for the car -- Must have #5 heads for your 69. I have a unassembled short block assembly that has been recently rebuilt with less than 1000 miles on it. Fresh bored .030 with new sealed Power small dish pistons, and a new Comp Cams with a near W-31 grind. Crank is NOT drilled for stick. It has an Edelbrock manifold with spread bore Holley. Dont have a stock 69 intake to sell. Email or PM me if youre interested. Was planning on taking this motor to Carlisle swap meet next week but will keep it here if your are interested. "make you good deal"!!
Old Sep 26, 2012 | 05:56 AM
Pacecar's Avatar
I have a 1969 350 - Engine is complete intake to oil pan. 4 barrel intake, A/C engine with the alternator bracket and three row water pump pulley. Was told engine ran when I got it. Has #5 heads correct heads I believe. Located Rochester NY
Old Oct 12, 2012 | 04:26 PM
Fummins's Avatar
Im in nor cal, may have some items you need.
Old Oct 14, 2012 | 07:37 PM
hotrodpc's Avatar
Nice to see all the offers and that the parts are available. Is OP going to respond? Anyone know if he still needs this or did he buy one?
805cut
May 3, 2012 08:11 PM
oldsman330
May 17, 2011 04:13 PM
vettemad
Mar 17, 2010 07:10 PM
import extermination
Aug 1, 2009 10:09 PM
geckonz08
Aug 21, 2008 07:58 PM
