Edelbrock 7111
Old Jun 2, 2025 | 07:40 PM
Sparks454's Avatar
Edelbrock 7111
Looking for a decent 7111 manifold for my 350. Let me know what you’ve got. Looks it should fit under the stock 71 supreme hood. And yes the engines being built to make good use of it..
thanks!
Old Jun 2, 2025 | 08:16 PM
70sgeek's Avatar
'72 Cutlass ragtop
Yes, it will fit under a stock hood - I run one on my 350 with a QuickFuel 780 carb with an approximate 1/2" spacer under it
Old Jun 3, 2025 | 03:35 AM
Sparks454's Avatar
Appreciate the response!
Old Jun 6, 2025 | 02:30 PM
Sparks454's Avatar
Anyone ever tried one of these? Looks like the edelbrock 7111 but marketed through JGhyperX store on Amazon. Same specs and no edelbrock logos which would make paint to match with the engine easy.. link below. Also looks like the heat crossover is modified underneath for roller lifter clearance..? Thoughts on the manifold would be great.. thanks
Amazon Amazon
Old Jun 6, 2025 | 04:52 PM
70sgeek's Avatar
'72 Cutlass ragtop
Think of it this way - How much are you investing in your motor that would justify saving $160 on an unknown quality 7111 knock-off (which interestingly advertises under the same Edelbrock part number (EDL-7111)?
I'd stick with the E-brock unless anyone else posts direct experience with the Amazon part
Old Jun 6, 2025 | 05:55 PM
Sparks454's Avatar
I appreciate the response, however it doesn’t really answer the question. That said, I understand what you’re saying. Was just curious if anyone had some experience with it. So many parts these days are simply relabeled items from other manufacturers and you never know exactly who manufactured it. They had some decent reviews for other intakes and some for their 455 manifolds that I found elsewhere. I don’t skimp on engine parts. Do it once and do it right.
Old Jun 6, 2025 | 07:09 PM
70sgeek's Avatar
'72 Cutlass ragtop
Hopefully someone with direct familiarity will weigh in but yeah, there are deals to be had on parts whose origins can be affirmed. For me, the thought of how much work and/or additional cost it takes to undo a mistake typically guides my judgment. on what to start with, even as much I appreciate the few times I actually have scored major savings on a successful chance part selection.
Old Jun 7, 2025 | 08:06 AM
ROCKETMAN269V's Avatar
I especially like the way they show "their" results using a MUSI 555 cu. in. BIG BLOCK CHEVY engine graph!
Old Jun 7, 2025 | 09:16 AM
Sparks454's Avatar
Haha.. right! That made me laugh too.
Old Jun 7, 2025 | 07:18 PM
DR_DAN's Avatar
I have one I don’t think has ever been mounted $375 shipped
Old Jun 8, 2025 | 09:42 AM
Sparks454's Avatar
sent you a PM. Thanks!
Grandpas_cutty
Jan 6, 2025 09:46 PM
redoldsman
Feb 8, 2022 11:22 AM
yeahbuddy
Mar 12, 2016 12:29 PM
Tony72Cutlass'S'
Jul 12, 2011 05:29 AM
71supreme
Sep 29, 2010 07:01 AM
