Dual Quad Manifold
There have only been three dual quad intakes ever made commercially for the big block Olds motor, not counting tunnel rams. My personal preference is the Edelbrock, which unfortunately has been out of production for decades. They show up regularly on ebay. The E-brock is a dual plane intake and works really well on the street.
Offy makes two different ones, the 360 and 180. The 360 is a very flat single plane intake with no contouring of the runners at all. They are best used as the basis for a supercharger manifold - BDS mills the carb flanges flat and welds on an aluminum plate to mount the blower. The 180 is possibly the goofiest intake ever conceived. It is basically the 360 casting with a vertical wall running down the middle of the plenum. The RH side of the carbs feed the RH cylinders and the LH side feed the LH cylinders. This runs counter to conventional dual plane manifold design where each side of the carb feeds alternating cylinders in the firing order. It should tell you something that in half a century, no other manufacturer has ever produced a manifold like that.
I have a Edelbrock O65 up for grabs - Dual plane dual quad manifold only, as Joe describes above. In good shape but has been glass beaded in the past. $425 plus safe shipping from Ohio.
No heat riser burn through, no water jacket corrosion. Did not chase threads, but all look good. In storage for decades.
Located in northern Ohio.
coldsmobile aht geeee mell daht kahm
TU
TU
Mark
Curious if anyone knows what 065 stands for, have this same intake purchased with my ;65 August built 442 in '75. Intake was in the trunk and I always wondered if this was Olds preview for the tri power intake in '66.
http://victorylibrary.com/mopar/edel.htm
It's just Edelbrock's designation and has nothing to do with Oldsmobile.
fast67vellen2o
March 31st, 2013 08:35 PM
