Dual Quad Manifold
Old Feb 22, 2018 | 11:36 AM
bob provost's Avatar
Dual Quad Manifold
Looking for a dual quad manifold for 1967 olds 400.
Old Feb 23, 2018 | 11:51 AM
4SPEED67's Avatar
The only dual 4 manifold that I have seen recently is an offenhauser. My buddy has one on his 425 in a 1968 442 with edelbrock carbs
Old Feb 23, 2018 | 01:29 PM
jcdynamic88's Avatar
https://newjersey.craigslist.org/pts...499295731.html not mine
Old Feb 23, 2018 | 01:39 PM
There have only been three dual quad intakes ever made commercially for the big block Olds motor, not counting tunnel rams. My personal preference is the Edelbrock, which unfortunately has been out of production for decades. They show up regularly on ebay. The E-brock is a dual plane intake and works really well on the street.
Offy makes two different ones, the 360 and 180. The 360 is a very flat single plane intake with no contouring of the runners at all. They are best used as the basis for a supercharger manifold - BDS mills the carb flanges flat and welds on an aluminum plate to mount the blower. The 180 is possibly the goofiest intake ever conceived. It is basically the 360 casting with a vertical wall running down the middle of the plenum. The RH side of the carbs feed the RH cylinders and the LH side feed the LH cylinders. This runs counter to conventional dual plane manifold design where each side of the carb feeds alternating cylinders in the firing order. It should tell you something that in half a century, no other manufacturer has ever produced a manifold like that.
Old Feb 24, 2018 | 06:16 AM
RickDuden's Avatar
Original Owner- 4spd A/C
Hi Bob.....I have a brand new Offy 360 dual quad manifold - if you are still looking and interested........you may msg me or call/text me at 405/214-8510..........thanks, Rick
Old Feb 25, 2018 | 08:46 AM
coldwar's Avatar
Sold - Gone - Thanks
Old Feb 25, 2018 | 10:53 AM
HX3's Avatar
HX3
Originally Posted by coldwar
I have a Edelbrock O65 up for grabs - Dual plane dual quad manifold only, as Joe describes above. In good shape but has been glass beaded in the past. $425 plus safe shipping from Ohio.
No heat riser burn through, no water jacket corrosion. Did not chase threads, but all look good. In storage for decades.
Located in northern Ohio.
coldsmobile aht geeee mell daht kahm
TU
If Bob doesn’t purchase your intake, I’m interested in buying it.
Mark
Old Feb 25, 2018 | 03:40 PM
RickDuden's Avatar
Mark
HI Mark.........I haven't heard a word from Bob about my intake.......so I will keep you posted........thanks, Rick
Old Feb 25, 2018 | 04:09 PM
cherokeepeople's Avatar
i have an offy and a pair of afb's on my toro gt engine.
Old Feb 25, 2018 | 04:31 PM
classicmuscle442's Avatar
Curious if anyone knows what 065 stands for, have this same intake purchased with my ;65 August built 442 in '75. Intake was in the trunk and I always wondered if this was Olds preview for the tri power intake in '66.
Old Feb 25, 2018 | 06:07 PM
HX3's Avatar
HX3
Appreciate the offer Rick ....
My earlier response is to coldwar for his Edelbrock O65 intake if Bob Provost doesn’t buy it.
Thanks, Mark
Old Feb 25, 2018 | 06:13 PM
RickDuden's Avatar
Mark........ok sorry , I thought your message was for me.........thanks, Rick
Old Feb 26, 2018 | 12:30 PM
Hi Rick, Got a shot at a tri-power manifold. Have to wait to see if it comes about. Thanks for the reply. Have a good year cruising.
Old Feb 28, 2018 | 04:54 PM
HX3's Avatar
HX3
Here’s a listing of early Edelbrock intake manifolds that are obsolete. You’ll see the O65 listed under Oldsmobile. ‘O’ simply indicated Oldsmobile.
http://victorylibrary.com/mopar/edel.htm
Old Feb 28, 2018 | 05:33 PM
It's just Edelbrock's designation and has nothing to do with Oldsmobile.
Old Mar 1, 2018 | 02:33 AM
65B01Delta's Avatar
Dual Quad
I seen this one a while back...
Old Mar 1, 2018 | 08:27 AM
That's just one of the single plane Offy manifolds. They were made in both square bore and spread bore versions. They also came in both low-rise and high-rise versions (not to be confused with the Offy tunnel ram).
Old Mar 1, 2018 | 11:26 AM
65B01Delta's Avatar
I guess it would be a good candidate for a blower manifold conversion....
67Olds442X2
Aug 28, 2014 03:43 AM
442garage
Apr 27, 2013 08:50 PM
fast67vellen2o
Mar 31, 2013 08:35 PM
47 Convertible
Jun 30, 2009 10:11 PM
bccsrc
Jan 30, 2008 07:22 AM
